912E/923 Transmission, I need some insight.... |
Britain Smith |
Jul 15 2004, 12:09 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Can anyone provide me with some random bits of information about the 912E transmission?
As you all know, am building a fairly powerful type-4 engine and I was headed down the path of mating it to a 915 transmission. I could either (A) use a conversion flywheel from Kennedy and machine it to match my dowel-pinned crank, or ((IMG:style_emoticons/default/cool.gif) use a 923 transmission from a 912E which has a type-4 mainshaft and would allow me to keep the dowel-pined, lightened flywheel that I already have. I know that the 923 tranny is a mag case with a 7:31 R&P which has it's own set of issues, but I need some additional information to sway me either way. I am also interested in some further explaination of the gearing. The 912E gearset looks like the following: 1976 (5-Spd) 11:35 11:33 23:29 26:25 29:21 7:31 Is there any reason why the first and second gears are so close in ratio to each other? I plugged this into my calculator and found that the 1-2 shift is ridiculously short...this can't be right. The 72-73 & 74 915's gearing looks like this: 1972-73 915 11:35 18:33 23:29 26:25 29:22 7:31 (5-Speed) 1974 915/06 11:35 18:33 23:29 27:25 29:21 7:31 (5-Speed) Do you think that a type-4 motor would be better off with the 912E gearing or the normal 915? Anyone? Jake...I know you have done a fair bit or research into this, any thoughts? -Britain |
Britain Smith |
Jul 15 2004, 03:25 PM
I have a file for both the 901 and 915 tranny with all the gears available that I know off...try these. Let me know if you need some help using it...I added to comments to the areas that need to be filled in by the used.
-Britain 901 Tranny Calculations 915 Tranny Calculations |
Lo-Fi Version | Time is now: 10th June 2024 - 01:29 AM |
