> Injector Click Test (outside of motor)
lsintampa
post Aug 11 2013, 10:20 AM
OK,
I hooked up a pig-tail to this injector. Then I got a 9V battery and tapped the pig-tail numerous times.
I never hear the injector click - and I'm assuming that it should.
The pig-tail does spark though - as if there is a short - which seems odd.
So, what is that telling me?
BTW - PO has said that all the injectors were cleaned and tested and all tested and sprayed well. They were however sitting in a baggy for three months. I can't imagine that they just went south????
All four injectors and the cold start valve all behave the same way.
Thanks,
Len
Porsche930dude
post Aug 11 2013, 06:24 PM
try some different test leads and a different battery. Im guessing there is a reason that plug isnt on the car anymore.
lsintampa   Injector Click Test (outside of motor)   Aug 11 2013, 10:20 AM
reharvey   These operate at 3 volts. I use a DC model train t...   Aug 11 2013, 11:21 AM
toadman   They do operate at 3V but, in the past I have test...   Aug 11 2013, 11:31 AM
lsintampa   OK, So there is NO click under power. They ohm ...   Aug 11 2013, 11:46 AM
Mark Henry   If the pintle won't budge after the soaking (i...   Aug 11 2013, 12:00 PM
r_towle   Dude, you have three threads going for the same pr...   Aug 11 2013, 02:56 PM
lsintampa   Dude, you have three threads going for the same p...   Aug 11 2013, 09:04 PM
Porsche930dude   try some different test leads and a different batt...   Aug 11 2013, 06:24 PM
lsintampa   Soaked overnight - no change. I spoke with the PO...   Aug 12 2013, 10:22 AM
Jeff Bowlsby   I have seen this before. The injectors must be in...   Aug 12 2013, 10:40 AM
speed metal army   Is the pigtail you made any good? Just a thought.....   Aug 12 2013, 10:41 AM
lsintampa   Is the pigtail you made any good? Just a thought....   Aug 12 2013, 11:00 AM
lsintampa   OK, Another question that I don't have an ans...   Aug 12 2013, 11:13 AM
SLITS   The electrical component inside is a solenoid. It...   Aug 12 2013, 11:19 AM
lsintampa   The electrical component inside is a solenoid. I...   Aug 12 2013, 11:26 AM
Jeff Bowlsby   You can hear a click when activated. Seems to me ...   Aug 12 2013, 11:41 AM
lsintampa   You can hear a click when activated. Seems to me...   Aug 12 2013, 11:52 AM
Jeff Bowlsby   You can hear a click when activated. Seems to m...   Aug 12 2013, 12:59 PM
timothy_nd28   Consider reading this thread, he went thru the sam...   Aug 12 2013, 01:00 PM
r_towle   did you soak them? If so, what did you soak them i...   Aug 12 2013, 01:14 PM
lsintampa   did you soak them? If so, what did you soak them ...   Aug 12 2013, 01:51 PM
pcar916   My 993 injectors were all frozen when I got the en...   Aug 12 2013, 01:16 PM
lsintampa   My 993 injectors were all frozen when I got the e...   Aug 12 2013, 01:55 PM
Jeff Bowlsby   They are obviously stuck closed. Send them in for...   Aug 12 2013, 01:59 PM
lsintampa   They are obviously stuck closed. Send them in fo...   Aug 12 2013, 02:11 PM
luskesq   They are obviously stuck closed. Send them in f...   Aug 12 2013, 04:13 PM
lsintampa   [quote name='lsintampa' post='1908174' date='Aug ...   Aug 12 2013, 06:52 PM
timothy_nd28   You should try installing a grease zerk on each in...   Aug 12 2013, 02:09 PM
r_towle   All a professional will do is soak them. If they w...   Aug 12 2013, 04:39 PM
Valy   I'm not sure Techtron will work. I used an ult...   Aug 12 2013, 06:15 PM
SLITS   Inside the fuel inlet, there is a micro-screen to ...   Aug 12 2013, 10:12 PM
lsintampa   Let's end this... I'm beyond guessing wh...   Aug 13 2013, 09:50 AM
worn   Let's end this... I'm beyond guessing w...   Aug 13 2013, 12:39 PM
lsintampa   Yeah, the shop just called. Two ultrasonic baths ...   Aug 13 2013, 12:57 PM
Jeff Bowlsby   Great way of looking at it Len. Lemonade from lem...   Aug 13 2013, 01:10 PM
Bob L.   Have you licked that 9v battery lately? You sure i...   Aug 13 2013, 03:11 PM
stugray   my thoughts exactly. We have similar "valv...   Aug 13 2013, 03:31 PM
worn   my thoughts exactly. We have similar "val...   Aug 16 2013, 11:02 AM
Valy   Oh... I got some captures. Ping me if I forget to ...   Aug 13 2013, 03:53 PM
lsintampa   For those following the drama. The shop couldn...   Aug 14 2013, 09:36 AM
aircooledtechguy   I just went through this on a friends car that use...   Aug 14 2013, 11:31 PM
lsintampa   I just went through this on a friends car that us...   Aug 15 2013, 08:47 AM
jsconst   Len, I just sent in 8 - 2.0 injectors for cleaning...   Aug 14 2013, 11:51 PM
lsintampa   Len, I just sent in 8 - 2.0 injectors for cleanin...   Aug 15 2013, 07:06 AM
jsconst   That would be sweet if you find them, good luck. ...   Aug 15 2013, 07:14 AM
aircooledtechguy   :thumbsup:   Aug 15 2013, 09:25 PM
Valy   Finally got to upload this. This is the power at ...   Aug 16 2013, 02:32 PM
r_towle   Cool, but where is the voltage?   Aug 16 2013, 04:34 PM
Valy   Cool, but where is the voltage? The voltage is t...   Aug 16 2013, 05:08 PM
stugray   Valy, Thanks for the scope capture. It sure looks...   Aug 16 2013, 10:41 PM
Valy   Valy, Thanks for the scope capture. It sure look...   Aug 16 2013, 11:47 PM
- Lo-Fi Version Time is now: 26th September 2025 - 08:25 AM
