| 914ltd |
Aug 11 2013, 08:25 PM
Member ![]() ![]() Group: Members Posts: 247 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
A real common 914 problem: The tabs mounted on the door post have worn and allow the new check strap to click as it reaches the next detent. A larger pin would eliminate the problem but enlarging the holes on the tabs is a problem with clearance issues. Any bright ideas? Thanks, Brad
| Bartlett 914 |
Aug 12 2013, 10:48 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,219 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I had the same problem with my green car. It wasn't too bad opening the hole to .250" and I used a 1/4" pin. I think I reamed it using a reamer and pliers. No room for a proper holder. 6mm =.236 vs .250 this is .007 per side. Considering it already oversize, even less.
914ltd Door check strap clicks, any solutions? Aug 11 2013, 08:25 PM
Dave_Darling You need a buddy with a welder and a six-pack of b... Aug 11 2013, 10:05 PM
siverson > The tabs mounted on the door post have worn
... Aug 12 2013, 12:09 AM
McMark
Yup. Aug 12 2013, 12:41 AM
r_towle right angle die grinder with a milling bit attache... Aug 12 2013, 12:10 PM
914ltd I intended to get the 1/4 ream (thanks, Mark) and ... Aug 18 2013, 05:42 PM
r_towle
I intended to get the 1/4 ream (thanks, Mark) and... Aug 19 2013, 11:12 AM
Bartlett 914
I intended to get the 1/4 ream (thanks, Mark) an... Aug 19 2013, 11:50 AM
Racer Chris
I just used a chucking reamer I had in my shop.
... Nov 21 2013, 04:14 PM
Bartlett 914
[quote name='Bartlett 914' post='1911675' date='A... Nov 21 2013, 06:59 PM
partwerks Brad,
Would clamping a piece of brass over the h... Aug 18 2013, 09:44 PM
914ltd
Brad,
Would clamping a piece of brass over the ... Aug 19 2013, 06:22 AM
kg6dxn I removed the one on the drivers side. Fuch it... ... Aug 18 2013, 11:53 PM
Firstcar I used a short bolt with a nylon nut in place of t... Aug 19 2013, 07:02 AM
Firstcar
I used a short bolt with a nylon nut in place of ... Aug 19 2013, 07:04 AM
cary I put in a brass bushing from the little drawers a... Aug 19 2013, 09:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th October 2026 - 08:38 PM |
