lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
OK,
I hooked up a pig-tail to this injector. Then I got a 9V battery and tapped the pig-tail numerous times. I never hear the injector click - and I'm assuming that it should. The pig-tail does spark though - as if there is a short - which seems odd. So, what is that telling me? BTW - PO has said that all the injectors were cleaned and tested and all tested and sprayed well. They were however sitting in a baggy for three months. I can't imagine that they just went south???? All four injectors and the cold start valve all behave the same way. Thanks, Len ![]() Attached thumbnail(s) ![]() |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
I'm not sure Techtron will work.
I used an ultrasonic bath with degreaser for about 10 minutes. It worked most of the time. I think the ultrasonic bath is the key. |
Lo-Fi Version | Time is now: 26th September 2025 - 08:22 AM |
