| jbachert |
Apr 5 2013, 09:26 AM
Newbie ![]() Group: Members Posts: 40 Joined: 2-January 13 From: Allentown, PA Member No.: 15,329 Region Association: North East States |
1973 1.7
OK - so I will start by saying it's my fault - I accidentally bumped and caused a short at the terminals on the fuse box on circuit 3 (low beams) - so at least we know the cause. The result is that: 1) The headlights do not work (parking lights, turns, etc do). No low beam, no high beam, no motor up for the headlights. (So technically I guess this is 4 circuits - circuits 1-4). 2) Everything on circuit 8 does not work (fresh air fan, horn, wipers, cigarette lighter). I know this is going to require tracing out circuits to see where/what isn't working and I just printed out the wiring diagrams and I have a digital multimeter ready to go. Just hoping for some advice from anybody who has some knowledge of the wiring as to where might be a good place to start, etc. Thanks, John |
| HalfMoon |
Aug 12 2013, 04:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
1973 1.7 OK - so I will start by saying it's my fault - I accidentally bumped and caused a short at the terminals on the fuse box on circuit 3 (low beams) - so at least we know the cause. The result is that: 1) The headlights do not work (parking lights, turns, etc do). No low beam, no high beam, no motor up for the headlights. (So technically I guess this is 4 circuits - circuits 1-4). 2) Everything on circuit 8 does not work (fresh air fan, horn, wipers, cigarette lighter). I know this is going to require tracing out circuits to see where/what isn't working and I just printed out the wiring diagrams and I have a digital multimeter ready to go. Just hoping for some advice from anybody who has some knowledge of the wiring as to where might be a good place to start, etc. Thanks, John Actually I just recently discovered on my 1973 that they used a horn relay and if it's bad ALL of fuse block#8 will be dead. It's the relay behind the fuse panel closet to the wall (left) |
| jbachert |
Aug 12 2013, 06:52 PM
1973 1.7 OK - so I will start by saying it's my fault - I accidentally bumped and caused a short at the terminals on the fuse box on circuit 3 (low beams) - so at least we know the cause. The result is that: 1) The headlights do not work (parking lights, turns, etc do). No low beam, no high beam, no motor up for the headlights. (So technically I guess this is 4 circuits - circuits 1-4). 2) Everything on circuit 8 does not work (fresh air fan, horn, wipers, cigarette lighter). I know this is going to require tracing out circuits to see where/what isn't working and I just printed out the wiring diagrams and I have a digital multimeter ready to go. Just hoping for some advice from anybody who has some knowledge of the wiring as to where might be a good place to start, etc. Thanks, John Actually I just recently discovered on my 1973 that they used a horn relay and if it's bad ALL of fuse block#8 will be dead. It's the relay behind the fuse panel closet to the wall (left) I figured out the problem quite some time ago (see my post above) - it wasn't a relay it was a bad ignition switch. |
jbachert Need help from wiring experts - two circuits not working Apr 5 2013, 09:26 AM
Cap'n Krusty Step ONE. Replace the fuses and CLEAN the contact... Apr 5 2013, 10:12 AM
76-914 Well we need to show a little more support than th... Apr 5 2013, 05:38 PM
jbachert 76-914 - Thanks for the advice. I think I have it... Apr 5 2013, 05:53 PM
Dave_Darling Excellent troubleshooting! Glad you found the... Apr 5 2013, 08:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 09:28 AM |
