lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
OK,
I hooked up a pig-tail to this injector. Then I got a 9V battery and tapped the pig-tail numerous times. I never hear the injector click - and I'm assuming that it should. The pig-tail does spark though - as if there is a short - which seems odd. So, what is that telling me? BTW - PO has said that all the injectors were cleaned and tested and all tested and sprayed well. They were however sitting in a baggy for three months. I can't imagine that they just went south???? All four injectors and the cold start valve all behave the same way. Thanks, Len ![]() Attached thumbnail(s) ![]() |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,053 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Great way of looking at it Len. Lemonade from lemons. You will like the D-Jet once it all comes together. I rarely have to fiddle with mine, and its very reliable.
Lo-Fi Version | Time is now: 26th September 2025 - 08:22 AM |
