> Injector Click Test (outside of motor)
lsintampa
post Aug 11 2013, 10:20 AM
OK,
I hooked up a pig-tail to this injector. Then I got a 9V battery and tapped the pig-tail numerous times.
I never hear the injector click - and I'm assuming that it should.
The pig-tail does spark though - as if there is a short - which seems odd.
So, what is that telling me?
BTW - PO has said that all the injectors were cleaned and tested and all tested and sprayed well. They were however sitting in a baggy for three months. I can't imagine that they just went south????
All four injectors and the cold start valve all behave the same way.
Thanks,
Len
stugray
post Aug 13 2013, 03:31 PM
Have you licked that 9v battery lately? You sure it's good?
my thoughts exactly.
We have similar "valves" in my business.
Our systems usually "Hit" the valve with full bus voltage (in the case of our cars that is ~13 Volts running), to open it.
Then the voltage drops to just a few volts to hold it open for extended periods.
I would not be surprised if these systems hit the injector with 12V at the start of the "fire" then backed it down to 3V for the duration.
I cannot see any captured waveforms of our injector pulses with an oscope online to be sure.
The rated coil resistance of these is 2-3 Ohms so "hitting" them with 12V from a reputable "source" :-) for a "touch test" should not hurt them. ("touch" meaning long enough to see the spark and no more)
I would try a nice stiff12V battery and a quick "touch" to see if you can free them after a good soaking.
Stu
lsintampa   Injector Click Test (outside of motor)   Aug 11 2013, 10:20 AM
reharvey   These operate at 3 volts. I use a DC model train t...   Aug 11 2013, 11:21 AM
toadman   They do operate at 3V but, in the past I have test...   Aug 11 2013, 11:31 AM
lsintampa   OK, So there is NO click under power. They ohm ...   Aug 11 2013, 11:46 AM
Mark Henry   If the pintle won't budge after the soaking (i...   Aug 11 2013, 12:00 PM
r_towle   Dude, you have three threads going for the same pr...   Aug 11 2013, 02:56 PM
lsintampa   Dude, you have three threads going for the same p...   Aug 11 2013, 09:04 PM
Porsche930dude   try some different test leads and a different batt...   Aug 11 2013, 06:24 PM
lsintampa   Soaked overnight - no change. I spoke with the PO...   Aug 12 2013, 10:22 AM
Jeff Bowlsby   I have seen this before. The injectors must be in...   Aug 12 2013, 10:40 AM
speed metal army   Is the pigtail you made any good? Just a thought.....   Aug 12 2013, 10:41 AM
lsintampa   Is the pigtail you made any good? Just a thought....   Aug 12 2013, 11:00 AM
lsintampa   OK, Another question that I don't have an ans...   Aug 12 2013, 11:13 AM
SLITS   The electrical component inside is a solenoid. It...   Aug 12 2013, 11:19 AM
lsintampa   The electrical component inside is a solenoid. I...   Aug 12 2013, 11:26 AM
Jeff Bowlsby   You can hear a click when activated. Seems to me ...   Aug 12 2013, 11:41 AM
lsintampa   You can hear a click when activated. Seems to me...   Aug 12 2013, 11:52 AM
Jeff Bowlsby   You can hear a click when activated. Seems to m...   Aug 12 2013, 12:59 PM
timothy_nd28   Consider reading this thread, he went thru the sam...   Aug 12 2013, 01:00 PM
r_towle   did you soak them? If so, what did you soak them i...   Aug 12 2013, 01:14 PM
lsintampa   did you soak them? If so, what did you soak them ...   Aug 12 2013, 01:51 PM
pcar916   My 993 injectors were all frozen when I got the en...   Aug 12 2013, 01:16 PM
lsintampa   My 993 injectors were all frozen when I got the e...   Aug 12 2013, 01:55 PM
Jeff Bowlsby   They are obviously stuck closed. Send them in for...   Aug 12 2013, 01:59 PM
lsintampa   They are obviously stuck closed. Send them in fo...   Aug 12 2013, 02:11 PM
luskesq   They are obviously stuck closed. Send them in f...   Aug 12 2013, 04:13 PM
lsintampa   [quote name='lsintampa' post='1908174' date='Aug ...   Aug 12 2013, 06:52 PM
timothy_nd28   You should try installing a grease zerk on each in...   Aug 12 2013, 02:09 PM
r_towle   All a professional will do is soak them. If they w...   Aug 12 2013, 04:39 PM
Valy   I'm not sure Techtron will work. I used an ult...   Aug 12 2013, 06:15 PM
SLITS   Inside the fuel inlet, there is a micro-screen to ...   Aug 12 2013, 10:12 PM
lsintampa   Let's end this... I'm beyond guessing wh...   Aug 13 2013, 09:50 AM
worn   Let's end this... I'm beyond guessing w...   Aug 13 2013, 12:39 PM
lsintampa   Yeah, the shop just called. Two ultrasonic baths ...   Aug 13 2013, 12:57 PM
Jeff Bowlsby   Great way of looking at it Len. Lemonade from lem...   Aug 13 2013, 01:10 PM
Bob L.   Have you licked that 9v battery lately? You sure i...   Aug 13 2013, 03:11 PM
stugray   my thoughts exactly. We have similar "valv...   Aug 13 2013, 03:31 PM
worn   my thoughts exactly. We have similar "val...   Aug 16 2013, 11:02 AM
Valy   Oh... I got some captures. Ping me if I forget to ...   Aug 13 2013, 03:53 PM
lsintampa   For those following the drama. The shop couldn...   Aug 14 2013, 09:36 AM
aircooledtechguy   I just went through this on a friends car that use...   Aug 14 2013, 11:31 PM
lsintampa   I just went through this on a friends car that us...   Aug 15 2013, 08:47 AM
jsconst   Len, I just sent in 8 - 2.0 injectors for cleaning...   Aug 14 2013, 11:51 PM
lsintampa   Len, I just sent in 8 - 2.0 injectors for cleanin...   Aug 15 2013, 07:06 AM
jsconst   That would be sweet if you find them, good luck. ...   Aug 15 2013, 07:14 AM
aircooledtechguy   :thumbsup:   Aug 15 2013, 09:25 PM
Valy   Finally got to upload this. This is the power at ...   Aug 16 2013, 02:32 PM
r_towle   Cool, but where is the voltage?   Aug 16 2013, 04:34 PM
Valy   Cool, but where is the voltage? The voltage is t...   Aug 16 2013, 05:08 PM
stugray   Valy, Thanks for the scope capture. It sure looks...   Aug 16 2013, 10:41 PM
Valy   Valy, Thanks for the scope capture. It sure look...   Aug 16 2013, 11:47 PM
- Lo-Fi Version Time is now: 26th September 2025 - 08:22 AM
