| rjames |
Aug 15 2013, 11:34 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,440 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Sorry if I've posted this in the wrong forum, admins please move if necessary.
I have a cousin who's husband just died of cancer. He owned an '81 911 SC Targa that has just under 100k miles on it. He drove it sparingly up until about 10+ years ago when he parked it in the garage and it sat. Last November he had the engined 'worked on' so he could start driving it again. He then drove it regularly for 6 months up until May when he passed away. In the last 6 months it has sat without being driven, ~90% of the oil leaked out. Upon quick inspection it looks like it had oil leaks from the pushrod tubes and the valve covers, but the bulk of the leak looks like it was coming from the front of the engine. I only had a vew minutes to crawl under it with only the light from my phone. Oil tank and cooler were clean. I'm trying to help my cousin assess it's value (in part to detirmine if I should buy it). I've told her to find a good mechanic to get an asessement before moving forward on anything and if possible, try and find out what the last mechanic did to it. Questions: Would a bad main seal cause that much oil to leak in 6 months? Anyone know a good Porsche mechanic in Spokane, Wa I can refer her to? |
| SLITS |
Aug 15 2013, 04:58 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The dipstick will show a very low level. As stated the oil drains into the engine sump.
You can only check oil level in a 911 engine up to temp, at idle and on level ground. Oil from the case is pumped back into the oil tank. I changed oil in my six once and forgot to drain the sump .... put 8 quarts in the tank and came out about 3 - 4 quarts overfull after starting the engine and it hadn't sat as long as you are talking about. Just food for thought. |
rjames '81 911 SC Oil leak question / Looking for mechanic Aug 15 2013, 11:34 AM
Jeffs9146 If it has oil feed chain tensioners I would check ... Aug 15 2013, 11:54 AM
barefoot
Sorry if I've posted this in the wrong forum,... Aug 15 2013, 02:53 PM
rjames
Sorry if I've posted this in the wrong forum... Aug 15 2013, 03:00 PM
SLITS When an assdragger engine sits, the case fills wit... Aug 15 2013, 03:08 PM
rjames
When an assdragger engine sits, the case fills wi... Aug 15 2013, 04:06 PM
rjames Good info. Thanks, everyone.
Wish I had easy ac... Aug 15 2013, 05:48 PM
r_towle call Emory Motorsports in Portland, they should kn... Aug 15 2013, 06:38 PM
cary http://www.alpinemotorcarsllc.com/porscherepairspo... Aug 15 2013, 11:53 PM
rjames Thanks for all of the info, everyone! Aug 16 2013, 11:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 06:44 PM |
