> Headlight won't pop up, Help!!
David Stowers
post Jul 16 2013, 12:14 PM
One of my lights doesn't come up. You can wind it up but if you go all the way up it then puts itself away again. If you wind it most of the way up it will go away if you switch them off. I've swapped the relays over and it makes no difference.
I'm rubbish with electrics so be gentle with me! Any suggestions?
Thanks
David Stowers
post Aug 16 2013, 10:57 AM
Thanks guys, the motor works as it will still close after its been manually opened. I've cleaned all the connections and earth (ground) points near the motors. I've not tackled the switch or fuse panel but figured if it was a problem there neither motor would function rather than just one.
It's driving me nuts (IMG:style_emoticons/default/headbang.gif)
David Stowers   Headlight won't pop up   Jul 16 2013, 12:14 PM
7TPorsh   start by checking around the lights for loose brow...   Jul 16 2013, 12:21 PM
David Stowers   start by checking around the lights for loose bro...   Jul 16 2013, 12:24 PM
sfrenck   start by checking around the lights for loose bro...   Jul 24 2013, 04:50 AM
7TPorsh   Is the driver's side normal?   Jul 16 2013, 02:48 PM
Eric_Shea   Is the driver's side normal? He's in th...   Jul 16 2013, 05:18 PM
76-914   Is the driver's side normal? He's in t...   Jul 16 2013, 05:30 PM
ripper911   Mine did that for a while. I think I just jiggled...   Jul 16 2013, 02:51 PM
Drums66   Mine did that for a while. I think I just jiggle...   Jul 16 2013, 06:53 PM
David Stowers   Drivers side is normal, I think I'll have to g...   Jul 16 2013, 03:03 PM
euro911   Has it always done this, or just recently? Mine w...   Jul 16 2013, 03:32 PM
David Stowers   I've not had it on the road yet since getting ...   Jul 16 2013, 03:38 PM
mrholland2   For headlights that won't "pop up", ...   Jul 16 2013, 03:42 PM
David Stowers   For headlights that won't "pop up",...   Jul 16 2013, 03:46 PM
mrholland2   For headlights that won't "pop up...   Jul 17 2013, 01:35 PM
David Stowers   [quote name='David Stowers' post='1895982' date='...   Jul 17 2013, 03:48 PM
Eric_Shea   Oh.... :blink: ("read" being the operat...   Jul 16 2013, 05:37 PM
jeeperjohn56   Had the same problem ended being a bad wire connec...   Jul 17 2013, 01:29 PM
euro911   I was joking with my cardiologist, told him I wa...   Jul 17 2013, 09:00 PM
7TPorsh   Alice doesn't live here anymore...   Jul 18 2013, 11:59 AM
David Stowers   Alice doesn't live here anymore... Alice, ...   Jul 24 2013, 03:54 AM
ripper911   Of course if you need to use your headlights befor...   Jul 24 2013, 05:30 AM
David Stowers   Of course if you need to use your headlights befo...   Aug 13 2013, 07:02 AM
David Stowers   Any ideas? Anyone? Pleeeeeaase!!!   Aug 14 2013, 02:10 AM
David Stowers   :bump:   Aug 15 2013, 03:18 AM
euro911   David, do you have an electrical wiring diagram? W...   Aug 15 2013, 09:04 AM
David Stowers   David, do you have an electrical wiring diagram? ...   Aug 15 2013, 12:13 PM
r_towle   hold up. Get some jumpers and unplug the motor an...   Aug 15 2013, 04:29 PM
HalfMoon   One of my lights doesn't come up. You can win...   Aug 15 2013, 06:04 PM
Porsche930dude   probrobly the connections. those motors are stout...   Aug 15 2013, 06:30 PM
mepstein   the motors rarely go bad. that's why they are ...   Aug 15 2013, 09:07 PM
David Stowers   Thanks guys, the motor works as it will still clos...   Aug 16 2013, 02:00 AM
David Stowers   Thanks guys, the motor works as it will still clos...   Aug 16 2013, 10:57 AM
r_towle   It's a home run circuit for each headlight all...   Aug 16 2013, 04:47 PM
- Lo-Fi Version Time is now: 18th March 2026 - 02:21 PM
