> everyone knows, I NEED hElP THANK YOU ALL!
worn
post Aug 16 2013, 09:22 AM
You may remember me from posts like the squid that ate my transmission. I built an engine and have pretty much solved various problems like leaks and oil pressure and oil temp. It is a 2056 with a 73 web cam + 2.5°.
I had to do some work on the heads. I was shooting for about a little over 8:1 compression, and while I have some uncertainty of deck height I am certain of the head chamber volume all matched to 69 cc ( I would say milliliters). According to CB Performance that would give me a maximum of 8.4 compression.
That is the set up here is the problem. On load I hear a ticking sound, with maybe a tinkling high tone. There are several alternative sources of rattling, but it is coming from the engine bay. The gas here is generally 91 octane. I have enriched the MPS to deliver A/F to around 11:1 at load with part throttle and that has not cured the problem. After break in the car turned more difficultly with the starter so I wonder if the cam may be producing better dynamic compression. The heads overheat if I push air down the road at 70 - they generally don't at 50. Timing is stock.
Question 1. Is this knock/ping/pink(UK)?
Question 2. What are my best options and how quickly must they be instituted. The car is grounded for now.
3 - Thanks!
worn
post Aug 16 2013, 01:35 PM
(IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)
- Lo-Fi Version Time is now: 5th March 2026 - 05:08 AM
