| lsintampa |
Aug 16 2013, 03:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 914/4 2.0 d-jet
I've posted many times for help with injectors, vac hoses, etc. I think I'm past that point now and need help figuring out why I can't start the car. I managed to get some signs of life, but only when I let the key off of the start position. In other words, while the motor is cranking, no signs of anything... then when I let the key go (back to the on position), it may or may not try to fire... got one decent backfire (smoke out the exhaust) one time. Battery is tired now, so I'm done until tomorrow. Car hasn't run in over 10 years, so it may be tired. Injectors are clean and tested OK out of the car. New starter. Hoses all connected - best I can tell. The oil breather hose is NOT connected to the air box, and I think there is one other outlet on the top of the air filter box without a hose. Did test for spark a while ago, seemed OK. Timing - IDK, I only see one mark on the fan and it's yellow - assume that to be TDC??? |
Jeff Bowlsby Len, review the troubleshooting chart in this docu... Aug 16 2013, 03:21 PM
lsintampa
Len, review the troubleshooting chart in this doc... Aug 16 2013, 08:25 PM
Spoke
then when I let the key go (back to the on positi... Aug 16 2013, 11:17 PM
Philip W. When I bought my 75 2.0. If I sprayed carb cleaner... Aug 17 2013, 12:25 AM
lsintampa
When I bought my 75 2.0. If I sprayed carb cleane... Aug 17 2013, 07:26 AM
Java2570 Have you verified fuel pressure is at 29-30 psi? I... Aug 17 2013, 08:06 AM
lsintampa
Have you verified fuel pressure is at 29-30 psi? ... Aug 17 2013, 09:35 AM
lsintampa UGH
Before I break something, tell me what's ... Aug 17 2013, 10:08 AM
lsintampa Pulled both valve covers off.
As it sits, one roc... Aug 17 2013, 11:16 AM
Java2570 If you pull the plugs, jack up one tire off the gr... Aug 17 2013, 11:34 AM
lsintampa
If you pull the plugs, jack up one tire off the g... Aug 17 2013, 12:12 PM
Bruce Allert I found a 2.0 in a broken car that sat under a tre... Aug 18 2013, 01:23 PM
JRust I thought you said it was turning over? If it was ... Aug 18 2013, 01:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 01:26 AM |
