gunny |
Member ![]() ![]() Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States ![]() |
I have had problems with High oil temps (240f) since I have owned the car when if I hit the highway for any period of time. It appears that I'm not able to cool the oil when at higher RPMs (above 3000) and the out side air is not cold. I have read every post that comes up in a search about oil flow and temp.
My car 1. 1976 2.0 D Jet cal with cat, pump and other extras removed 2. 20w50 oil 3. car runs very good and smooth (I don't have any other 914s to compare to) 4. idal good and steady(1100 cool, 950 warm) 5. no oil leaks (IMG:style_emoticons/default/aktion035.gif) I have added the following gages to better monitor this problem 1. Oil temp gage 2. Oil pressure gage (pressure >70psi at initial start, goes down to about 15 at idal and oil temp about 200, when oil tem goes higher pressur goes lower than 10 psi per 1000 rmp) 3. wideband 02 (12.5-13 at steady speed, goes down to about 10 at WOT for a few seconds then climbs to 11+ untill steady speed then about 12.5) (will go high 14+ for about 1 second at WOT while passing thru 3700 RPMs then back down to 12.5) I have checked or done the following work 1. adjusted/varified the valves, timeing , dwell, TPS 2. Injectors cleaned and flow tested (made motor run much better and smoother) 3. MPS hold vacuum 4. I have done all of the ECU Ohms checks 5. I have varified that my flap is coming down and covering the Oil cooler 6. I have no debris on the cooler or air flow to the oil cooler 7. I have all of the tins on the car, I have the 2 plastic air dams under the car 8. The fan is not missing any blades but does still have the pump pulley atached(I plan on removing when I take the motor out) 9. I have installed the higher oil relief spring and valve (problem did not change) 10. I have learned a lot about D-Jet theory 11. I'm still having fun but would like to be able to drive it more Any other suggestions would be appreaciated. |
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,493 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
I have had problems with High oil temps (240f) since I have owned the car when if I hit the highway for any period of time. It appears that I'm not able to cool the oil when at higher RPMs (above 3000) and the out side air is not cold. I have read every post that comes up in a search about oil flow and temp. My car 1. 1976 2.0 D Jet cal with cat, pump and other extras removed 2. 20w50 oil 3. car runs very good and smooth (I don't have any other 914s to compare to) 4. idal good and steady(1100 cool, 950 warm) 5. no oil leaks (IMG:style_emoticons/default/aktion035.gif) I have added the following gages to better monitor this problem 1. Oil temp gage 2. Oil pressure gage (pressure >70psi at initial start, goes down to about 15 at idal and oil temp about 200, when oil tem goes higher pressur goes lower than 10 psi per 1000 rmp) 3. wideband 02 (12.5-13 at steady speed, goes down to about 10 at WOT for a few seconds then climbs to 11+ untill steady speed then about 12.5) (will go high 14+ for about 1 second at WOT while passing thru 3700 RPMs then back down to 12.5) I have checked or done the following work 1. adjusted/varified the valves, timeing , dwell, TPS 2. Injectors cleaned and flow tested (made motor run much better and smoother) 3. MPS hold vacuum 4. I have done all of the ECU Ohms checks 5. I have varified that my flap is coming down and covering the Oil cooler 6. I have no debris on the cooler or air flow to the oil cooler 7. I have all of the tins on the car, I have the 2 plastic air dams under the car 8. The fan is not missing any blades but does still have the pump pulley atached(I plan on removing when I take the motor out) 9. I have installed the higher oil relief spring and valve (problem did not change) 10. I have learned a lot about D-Jet theory 11. I'm still having fun but would like to be able to drive it more Any other suggestions would be appreaciated. I have the same car. 1976 stock 2.0 D-Jet. Notice Porsche changed what they consider to be too hot when the introduced the 2.0 by changing where they painted the red on the gauge. In my opinion the engines are over built to as far as they could with a production engine. I put a cheap external cooler next to the tranny on the passenger side - these kits abound on VW vendor sites. No fan and back there it isn't any too cool, but it is enough to get rid of the problem for me. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I have had problems with High oil temps (240f) since I have owned the car when if I hit the highway for any period of time. It appears that I'm not able to cool the oil when at higher RPMs (above 3000) and the out side air is not cold. I have read every post that comes up in a search about oil flow and temp. My car 1. 1976 2.0 D Jet cal with cat, pump and other extras removed 2. 20w50 oil 3. car runs very good and smooth (I don't have any other 914s to compare to) 4. idal good and steady(1100 cool, 950 warm) 5. no oil leaks (IMG:style_emoticons/default/aktion035.gif) I have added the following gages to better monitor this problem 1. Oil temp gage 2. Oil pressure gage (pressure >70psi at initial start, goes down to about 15 at idal and oil temp about 200, when oil tem goes higher pressur goes lower than 10 psi per 1000 rmp) 3. wideband 02 (12.5-13 at steady speed, goes down to about 10 at WOT for a few seconds then climbs to 11+ untill steady speed then about 12.5) (will go high 14+ for about 1 second at WOT while passing thru 3700 RPMs then back down to 12.5) I have checked or done the following work 1. adjusted/varified the valves, timeing , dwell, TPS 2. Injectors cleaned and flow tested (made motor run much better and smoother) 3. MPS hold vacuum 4. I have done all of the ECU Ohms checks 5. I have varified that my flap is coming down and covering the Oil cooler 6. I have no debris on the cooler or air flow to the oil cooler 7. I have all of the tins on the car, I have the 2 plastic air dams under the car 8. The fan is not missing any blades but does still have the pump pulley atached(I plan on removing when I take the motor out) 9. I have installed the higher oil relief spring and valve (problem did not change) 10. I have learned a lot about D-Jet theory 11. I'm still having fun but would like to be able to drive it more Any other suggestions would be appreaciated. I have the same car. 1976 stock 2.0 D-Jet. Notice Porsche changed what they consider to be too hot when the introduced the 2.0 by changing where they painted the red on the gauge. In my opinion the engines are over built to as far as they could with a production engine. I put a cheap external cooler next to the tranny on the passenger side - these kits abound on VW vendor sites. No fan and back there it isn't any too cool, but it is enough to get rid of the problem for me. To say the motor was over built as far as they could go with a production engine is just malarkey. You drive a 2056 and jake has built some big motors with this basic platform many times. A 2.4 motor running stock djet or ljet while still. Running cool and performing quite well is simple to build and really a great extension of the platform. Vw built these motors to last, so they left loads of room for improvement, but at the sacrifice of efficiency. To this day I am still fascinated by a package that can be removed as a unit, and bolted into another car, so simply it's amazing. Easy to fix, tune, and troubleshoot...parts are still cheap for basic maintenance and if you look at the roots of the beetle with 20mm units built, it's an cool piece of engineering. Looking at the Subaru, to me at least, is the natural extension of the vw 4 cylinder platform. |
worn |
To say the motor was over built as far as they could go with a production engine is just malarkey. You drive a 2056 and jake has built some big motors with this basic platform many times. A 2.4 motor running stock djet or ljet while still. Running cool and performing quite well is simple to build and really a great extension of the platform. Vw built these motors to last, so they left loads of room for improvement, but at the sacrifice of efficiency. To this day I am still fascinated by a package that can be removed as a unit, and bolted into another car, so simply it's amazing. Easy to fix, tune, and troubleshoot...parts are still cheap for basic maintenance and if you look at the roots of the beetle with 20mm units built, it's an cool piece of engineering. Looking at the Subaru, to me at least, is the natural extension of the vw 4 cylinder platform. I think I wasn't careful enough. Back in the day I was in college and I never knew of a bus with a reasonable air cooled engine life. The owners weren't going to the races, they were going to the work on the Seattle freeways burning up two liter motors. This matches my own readings of posts here and service manuals, and in books. I think it extends over to Porsches, which at the time did not enjoy a reputation of owner satisfaction regarding reliability. If you follow the nine eleven they got to a point where head and engine cooling was an issue that would have been surmountable at two liters but was very hard at well over three. So I think our engines are a bit finicky at two liters. That last sentence. I had trouble with oil cooling with a stock worn engine and I am having trouble with oil cooling with a mildly modified engine. Jake charges what even in dollars as old as I am would have been more than porsche could have afforded, so I meant to exclude him and other people who can hand build. I was driving my tr6 yesterday. I hand built that car with every bolt. But I was driving it to visit the 914 (IMG:style_emoticons/default/beerchug.gif) I feel more secure in the teen, and now it packs more muscle. No knocks intended. Or wanted, sigh... |
Lo-Fi Version | Time is now: 26th August 2025 - 09:45 PM |
