| worn |
Aug 16 2013, 09:22 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,555 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
You may remember me from posts like the squid that ate my transmission. I built an engine and have pretty much solved various problems like leaks and oil pressure and oil temp. It is a 2056 with a 73 web cam + 2.5°.
I had to do some work on the heads. I was shooting for about a little over 8:1 compression, and while I have some uncertainty of deck height I am certain of the head chamber volume all matched to 69 cc ( I would say milliliters). According to CB Performance that would give me a maximum of 8.4 compression. That is the set up here is the problem. On load I hear a ticking sound, with maybe a tinkling high tone. There are several alternative sources of rattling, but it is coming from the engine bay. The gas here is generally 91 octane. I have enriched the MPS to deliver A/F to around 11:1 at load with part throttle and that has not cured the problem. After break in the car turned more difficultly with the starter so I wonder if the cam may be producing better dynamic compression. The heads overheat if I push air down the road at 70 - they generally don't at 50. Timing is stock. Question 1. Is this knock/ping/pink(UK)? Question 2. What are my best options and how quickly must they be instituted. The car is grounded for now. 3 - Thanks! |
| r_towle |
Aug 16 2013, 04:39 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
What distributor?
What fuel source? What carbs? What is the setup on the carbs? |
| worn |
Aug 16 2013, 08:41 PM
What distributor? What fuel source? What carbs? What is the setup on the carbs? Glad you asked. This has run me from pillar to post in an interesting way. I am learning a lot, but can do that when the snow falls and the salt vampires hit the road. I am running D-jet. I rechecked my scraps of paper and compression has an upper limit at 9.7 if I completely mressed up and have no deck height (doubt) down to 8.7 if I did the deck height right at 40 thou. I am running gas from a Stop and Go that advertises recreational gas with no ethanol. Force of habit with old cars. 91 octane, but I now realize that ethanol might be good at boosting octane, snd I might be able to get 93 elsewhere at a name brand. I added a 6AL cd ignition and I thought about adjustable retard - just right for me - to go with it, but the red box only lasted about a couple of weeks. New out of box but off warrantee due to stashing away. I finally got the D Jet to play nice. I find the car runs better a bit leaner, but right now the car cruises at 12:1 and is pinking at 11. Charge cooling isn't going to do it for me. I am guessing I have flame fronts moving unevenly in the squish zone after ignition. I may buy one of those microphones you attach to different places and drive around with head phones. I came so far. The car runs like a champ. Help! (IMG:style_emoticons/default/blink.gif) |
worn everyone knows Aug 16 2013, 09:22 AM
worn :idea: :popcorn: Aug 16 2013, 01:35 PM
kg6dxn The pinging, overheating and hard start is indicit... Aug 16 2013, 01:36 PM
worn
The pinging, overheating and hard start is indici... Aug 16 2013, 04:35 PM
worn
What distributor?
What fuel source? What carbs? W... Aug 19 2013, 09:47 AM
messix the engine most likely does not need as much ... Aug 16 2013, 08:19 PM
john rogers I would say the problem is the D-Jet system. Unles... Aug 16 2013, 08:47 PM
stugray Any chance you "upgraded" the oil pump d... Aug 18 2013, 01:32 PM
worn
Any chance you "upgraded" the oil pump ... Aug 19 2013, 09:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 03:40 AM |
