lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
OK,
I hooked up a pig-tail to this injector. Then I got a 9V battery and tapped the pig-tail numerous times. I never hear the injector click - and I'm assuming that it should. The pig-tail does spark though - as if there is a short - which seems odd. So, what is that telling me? BTW - PO has said that all the injectors were cleaned and tested and all tested and sprayed well. They were however sitting in a baggy for three months. I can't imagine that they just went south???? All four injectors and the cold start valve all behave the same way. Thanks, Len ![]() Attached thumbnail(s) ![]() |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Valy,
Thanks for the scope capture. It sure looks like a full 12-13 volts at the injector. I couldnt figure out the rate... Every 13ms (period) is ~77 Hz yet the description was high revs.... I dont understand the injector timing for these. You can even see the injector valve (pintle?) response time at ~2ms. It would be cool to have a current trace to go along with that voltage trace. However based on that Voltage trace, the injectors use 12V when running. Stu |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Valy, Thanks for the scope capture. It sure looks like a full 12-13 volts at the injector. I couldnt figure out the rate... Every 13ms (period) is ~77 Hz yet the description was high revs.... I dont understand the injector timing for these. You can even see the injector valve (pintle?) response time at ~2ms. It would be cool to have a current trace to go along with that voltage trace. However based on that Voltage trace, the injectors use 12V when running. Stu 77 revolutions/second = 77*60 revolutions/minute=4620 RPM |
Lo-Fi Version | Time is now: 26th September 2025 - 08:25 AM |
