> Front End Bracing
57lincolnman
post Aug 17 2013, 08:41 PM
My 75 has a dealer installed a/c unit. The lower pan in the front trunk was cut out years ago by the dealer. Has anyone tried to fabricate cross bracing to tighten the front end? I think the structural integrity of the unibody was compromised by this "dealer authorized" surgical procedure. Interested in your thoughts. Thanks.
messix
post Aug 17 2013, 08:50 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
if it's just the sheet metal behind the front part of the trunk after about 3" and along the sides 2" from the front sub frame box it should be ok.
looks bad but the strength is in the box sections
57lincolnman
post Aug 17 2013, 08:59 PM
QUOTE(messix @ Aug 17 2013, 06:50 PM) *
I suppose what I lost in the transaction was the toe hook (mounted in that section of the panel removed) and drain tubes.
57lincolnman   Front End Bracing   Aug 17 2013, 08:41 PM
messix   if it's just the sheet metal behind the front ...   Aug 17 2013, 08:50 PM
57lincolnman   if it's just the sheet metal behind the front...   Aug 17 2013, 08:57 PM
57lincolnman   if it's just the sheet metal behind the front...   Aug 17 2013, 08:59 PM
messix   if it's just the sheet metal behind the fron...   Aug 17 2013, 09:22 PM
SirAndy   it should be ok. I dis-agree ... I think any cut...   Aug 17 2013, 09:42 PM
messix   I think the only forces put on that section is hor...   Aug 17 2013, 09:56 PM
FourBlades   Restoration Design just started making a perfect p...   Aug 17 2013, 10:01 PM
messix   Restoration Design just started making a perfect ...   Aug 17 2013, 10:05 PM
FourBlades   Restoration Design just started making a perfect...   Aug 17 2013, 10:08 PM
messix   I just went out to put my '75 back in the gara...   Aug 17 2013, 10:24 PM
Racer Chris   ...if it's just a street car I don't thin...   Aug 18 2013, 07:38 AM
914Sixer   Yes, 75-76 do have a little more structure to them...   Aug 18 2013, 06:44 AM
jimkelly   comparision   Aug 18 2013, 06:57 AM
rhodyguy   cracks can result that run towards the front contr...   Aug 18 2013, 08:27 AM
57lincolnman   I have invested quite a bit to have working a/c, s...   Aug 18 2013, 10:24 AM
Racer Chris   I have invested quite a bit to have working a/c, ...   Aug 18 2013, 04:44 PM
zambezi   Heres what I did. Not sure if it added any struct...   Aug 18 2013, 11:54 AM
Larry Hubby   If you've ever looked at the floor of the fron...   Aug 18 2013, 06:01 PM
sean_v8_914   if anyone has evidence of stresses in this area, p...   Aug 18 2013, 07:58 PM
Krieger   When I started to take my 75, that had A/C, apart ...   Aug 18 2013, 08:25 PM
Racer Chris   This car had the full trunk floor intact. Cracks o...   Aug 19 2013, 07:37 AM
Eric_Shea   :agree: I've seen pictures of a bad bushing li...   Aug 19 2013, 08:56 AM
sean_v8_914   right along th spot weld line   Aug 19 2013, 10:27 AM
- Lo-Fi Version Time is now: 6th March 2026 - 09:58 PM
