> High Oil temp, I need suggestions (good ones)
gunny
post Aug 16 2013, 11:10 AM
I have had problems with High oil temps (240f) since I have owned the car when if I hit the highway for any period of time. It appears that I'm not able to cool the oil when at higher RPMs (above 3000) and the out side air is not cold. I have read every post that comes up in a search about oil flow and temp.
My car
1. 1976 2.0 D Jet cal with cat, pump and other extras removed
2. 20w50 oil
3. car runs very good and smooth (I don't have any other 914s to compare to)
4. idal good and steady(1100 cool, 950 warm)
5. no oil leaks (IMG:style_emoticons/default/aktion035.gif)
I have added the following gages to better monitor this problem
1. Oil temp gage
2. Oil pressure gage (pressure >70psi at initial start, goes down to about 15 at idal and oil temp about 200, when oil tem goes higher pressur goes lower than 10 psi per 1000 rmp)
3. wideband 02 (12.5-13 at steady speed, goes down to about 10 at WOT for a few seconds then climbs to 11+ untill steady speed then about 12.5) (will go high 14+ for about 1 second at WOT while passing thru 3700 RPMs then back down to 12.5)
I have checked or done the following work
1. adjusted/varified the valves, timeing , dwell, TPS
2. Injectors cleaned and flow tested (made motor run much better and smoother)
3. MPS hold vacuum
4. I have done all of the ECU Ohms checks
5. I have varified that my flap is coming down and covering the Oil cooler
6. I have no debris on the cooler or air flow to the oil cooler
7. I have all of the tins on the car, I have the 2 plastic air dams under the car
8. The fan is not missing any blades but does still have the pump pulley atached(I plan on removing when I take the motor out)
9. I have installed the higher oil relief spring and valve (problem did not change)
10. I have learned a lot about D-Jet theory
11. I'm still having fun but would like to be able to drive it more
Any other suggestions would be appreaciated.
post Aug 16 2013, 01:17 PM
I don't see where you verified the oil temp. New gauge doesn't count.
57lincolnman
post Aug 17 2013, 09:19 PM
QUOTE(76-914 @ Aug 16 2013, 11:17 AM) *
I have a 75 that had similar high oil temps issues. It has an auxiliary oil cooler with a fan mounted on the backside controlled with a thermostat to come on at 180F. I still had problems with oil temps reaching 240F. I put a vent scoop (2 2/2") on the passenger side rocker panel that channels air through a hose directly onto the auxiliary oil cooler. The aux oil cooler has "fins" on each side to help direct the air. That did the trick! My oil temps are now consistently in the 210F range with oil pressure at 40psi @ 3400 RPM (75 mph). Even on steep hill climbs it may get to 220. Prior to this set-up it would climb to 240F+. Idea came from Chris Foley at Tangerine Racing.
gunny   High Oil temp   Aug 16 2013, 11:10 AM
worn   I have had problems with High oil temps (240f) si...   Aug 16 2013, 11:27 AM
Racer Chris   Notice Porsche changed what they consider to be t...   Aug 16 2013, 01:42 PM
worn   Notice Porsche changed what they consider to be ...   Aug 16 2013, 07:55 PM
r_towle   I have had problems with High oil temps (240f) s...   Aug 16 2013, 06:55 PM
worn   To say the motor was over built as far as they co...   Aug 16 2013, 08:10 PM
76-914   I don't see where you verified the oil temp. N...   Aug 16 2013, 01:17 PM
57lincolnman   I don't see where you verified the oil temp. ...   Aug 17 2013, 09:19 PM
Cap'n Krusty   The EGR is there in the '75-'76 cars to co...   Aug 16 2013, 01:49 PM
toadman   The EGR is there in the '75-'76 cars to c...   Aug 16 2013, 08:17 PM
Trekkor   Front mounted oil cooler should have been an OEM f...   Aug 16 2013, 01:54 PM
chad newton   Front mounted oil cooler should have been an OEM ...   Aug 19 2013, 03:42 PM
r_towle   Gunny, If you are dealing with temps that make yo...   Aug 16 2013, 06:59 PM
Eric_Shea   Beyond the fan blades, what have you looked into w...   Aug 16 2013, 10:49 PM
larss   Have you checked the two air defectors under the c...   Aug 17 2013, 04:04 AM
eyesright   Here in Oklahoma my home rebuilt 2.0 D-Jet is runi...   Aug 17 2013, 07:11 AM
MikeM   Gunny...I have the same problem with my car. At th...   Aug 17 2013, 08:50 AM
57lincolnman   I had a similar problem with my 75 1.8L. It has a...   Aug 17 2013, 09:29 PM
patrick3000   I had a similar problem with my 75 1.8L. It has ...   Aug 19 2013, 01:24 PM
gunny   I have had problems with High oil temps (240f) si...   Aug 18 2013, 06:01 PM
Eric_Shea   I'd drop #6 off the list and just get the righ...   Aug 19 2013, 08:30 AM
r_towle   I'd drop #6 off the list and just get the rig...   Aug 19 2013, 10:47 AM
worn   I'd drop #6 off the list and just get the ri...   Aug 19 2013, 11:58 AM
gunny   I'd drop #6 off the list and just get the ri...   Aug 19 2013, 01:01 PM
gunny   I'd drop #6 off the list and just get the rig...   Aug 19 2013, 10:57 AM
larss   Gunny, just for my curiosity, are the two air defl...   Aug 19 2013, 12:21 PM
gunny   Gunny, just for my curiosity, are the two air def...   Aug 19 2013, 12:54 PM
larss   [quote name='larss' post='1911686' date='Aug 19 2...   Aug 19 2013, 01:02 PM
gunny   [quote name='larss' post='1911686' date='Aug 19 ...   Aug 19 2013, 01:13 PM
larss   Yes I have them both. Good, then i can relax...   Aug 19 2013, 01:17 PM
- Lo-Fi Version Time is now: 26th August 2025 - 09:44 PM
