> Brakes... Don't lockup, Good or Bad...
jesiv
post Aug 17 2013, 07:01 PM
Several weeks ago I replaced all the rotors, pads and flushed the brake fluid. I used the Motive pressurized brake bleeder using two quarts of fluid to really flush the system. The emergency brake works perfectly and the car stops great. However I can't get the brakes to lock up. I have brand new eagle GTs 195.65.15 with obviously lots of tread. I am wondering if something is not quite right since I can't lock the wheels. The brake pedal is hard but the won't lock. Should I be concerned? The pads have several hundred miles now.
Should I consider not locking up a good thing or do I need to consider this a harbinger of failures to come...
Thanks for your thoughts
Regards
James
solex
post Aug 17 2013, 09:13 PM
Do a quick search your brakes should not lock up. If they do than you are no longer in control.
jesiv
post Aug 17 2013, 09:34 PM
QUOTE(solex @ Aug 17 2013, 08:13 PM) *
I don't mean that I want them to! I just want toknow that at some point they will. My 1971 914-6 did, my 1976 2.0 did and this one did until I replaced the wheels, tires, rotors and pads.
I am researching "brake bedding" but have not found Eric's thread. So anyone knows the link please post it
Regards
James
jesiv   Brakes... Don't lockup   Aug 17 2013, 07:01 PM
kg6dxn   You need to bed the pads per Eric Shea's direc...   Aug 17 2013, 07:25 PM
tracks914   First find some gravel, might be hard to do in Cal...   Aug 17 2013, 08:04 PM
jesiv   If I do what sort of problem would I have? Regard...   Aug 17 2013, 08:51 PM
solex   Do a quick search your brakes should not lock up. ...   Aug 17 2013, 09:13 PM
jesiv   Do a quick search your brakes should not lock up....   Aug 17 2013, 09:34 PM
FourBlades   I had the same problem after replacing my brakes w...   Aug 17 2013, 10:07 PM
solex   I had the same problem after replacing my brakes ...   Aug 17 2013, 11:01 PM
Trekkor   914's are not equipped with anti-lock brakes. ...   Aug 17 2013, 10:08 PM
Andyrew   At lower speeds I dont think you have enough press...   Aug 17 2013, 10:43 PM
jesiv   I am trying to lock them up to confirm they are wo...   Aug 18 2013, 09:58 AM
r3dplanet   Watching with great interest. I replaced all of my...   Aug 18 2013, 10:07 AM
mepstein   Are you guys using 19mm mc's? 17mm is more pow...   Aug 18 2013, 10:26 AM
Andyrew   High performance pads need to be beaded in with LO...   Aug 18 2013, 10:47 AM
stugray   Just drove my hanger queen for her first few ...   Aug 18 2013, 08:30 PM
jesiv   Well I try to do the bedding but it is hard to in ...   Aug 18 2013, 08:49 PM
stugray   I have had brand new Eagle GTs with the stickers s...   Aug 18 2013, 09:10 PM
Eric_Shea   Anything under a narrow body car should lock up. ...   Aug 18 2013, 09:24 PM
- Lo-Fi Version Time is now: 4th March 2026 - 12:10 PM
