| TheCabinetmaker |
Aug 12 2013, 06:59 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Stopped at a red light and tach dropped to 0, and engine died. Started right back up, but wouldn't idle. Made it back to my shop by keeping the rpms up when stopped. Runsu just fine, just won't idle. Unplugged the tps and it idles fine. Plug it back in, and engine dies. Haven't got to look at it yet, wondered if anyone else has experienced this and what the cause was. 40 years, and this is a first.
| TheCabinetmaker |
Aug 18 2013, 11:58 AM
Sorry Ray, it was mostly a process of elimination. Wiring checked good, tps adjusted to 0 ohms. Using brad anders chart I checked ohms at #17 wire on the ecu plug. He called for under .5 ohms. After dismantling a tps and sanding the gold on the board, then hand polishing it with jewellers rouge, it ohmed at .2. No change. It just had to be the ecu. Since I already had the plug off, it was simple to check.
The Cabinetmaker car died today Aug 12 2013, 06:59 PM
type47 I had mine suddenly run really crappy, turned out ... Aug 13 2013, 07:07 AM
sportlicherFahrer I would try cleaning the contact plate inside the ... Aug 13 2013, 11:53 AM
Tom_T Curt -
Someone on here in member vendors was maki... Aug 13 2013, 11:59 AM
The Cabinetmaker I have a new board that has been adjusted. I'm... Aug 13 2013, 04:33 PM
76-914
I have a new board that has been adjusted. I... Aug 14 2013, 02:45 PM
r_towle Let or djet?
Vacuum leak on ljet will do this...... Aug 14 2013, 09:12 PM
Cap'n Krusty The car will idle and run fairly well with the TPS... Aug 14 2013, 09:57 PM
The Cabinetmaker You are correct as usual Cap'n, but you alread... Aug 15 2013, 06:40 PM
Java2570 That is a bizarre one.....maybe a break in the wir... Aug 17 2013, 08:10 AM
The Cabinetmaker I just got done with my yardwork this morning and ... Aug 17 2013, 10:34 AM
rmital
I just got done with my yardwork this morning and... Aug 17 2013, 10:56 AM
The Cabinetmaker Got it fixed turned out to be the ecu. all is good... Aug 17 2013, 03:14 PM
rmital
Got it fixed turned out to be the ecu. all is goo... Aug 18 2013, 11:18 AM
76-914 File a complaint, Curt. You were cheated. These th... Aug 18 2013, 10:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 01:46 AM |
