| 57lincolnman |
Aug 17 2013, 08:41 PM
Member ![]() ![]() Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
My 75 has a dealer installed a/c unit. The lower pan in the front trunk was cut out years ago by the dealer. Has anyone tried to fabricate cross bracing to tighten the front end? I think the structural integrity of the unibody was compromised by this "dealer authorized" surgical procedure. Interested in your thoughts. Thanks.
| Krieger |
Aug 18 2013, 08:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,841 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
When I started to take my 75, that had A/C, apart in 1991 I had to repair a tear/ crack on the frame. It was near where the front A-arm bolts up on the driver side. I'm pretty sure the car was not an autocross/ TT car. The crack was about 1.5"
57lincolnman Front End Bracing Aug 17 2013, 08:41 PM
messix if it's just the sheet metal behind the front ... Aug 17 2013, 08:50 PM
57lincolnman
if it's just the sheet metal behind the front... Aug 17 2013, 08:57 PM
57lincolnman
if it's just the sheet metal behind the front... Aug 17 2013, 08:59 PM
messix
if it's just the sheet metal behind the fron... Aug 17 2013, 09:22 PM
SirAndy it should be ok.
I dis-agree ...
I think any cut... Aug 17 2013, 09:42 PM
messix I think the only forces put on that section is hor... Aug 17 2013, 09:56 PM
FourBlades Restoration Design just started making a perfect p... Aug 17 2013, 10:01 PM
messix
Restoration Design just started making a perfect ... Aug 17 2013, 10:05 PM
FourBlades
Restoration Design just started making a perfect... Aug 17 2013, 10:08 PM
messix I just went out to put my '75 back in the gara... Aug 17 2013, 10:24 PM
Racer Chris
...if it's just a street car I don't thin... Aug 18 2013, 07:38 AM
914Sixer Yes, 75-76 do have a little more structure to them... Aug 18 2013, 06:44 AM
jimkelly comparision Aug 18 2013, 06:57 AM
rhodyguy cracks can result that run towards the front contr... Aug 18 2013, 08:27 AM
57lincolnman I have invested quite a bit to have working a/c, s... Aug 18 2013, 10:24 AM
Racer Chris
I have invested quite a bit to have working a/c, ... Aug 18 2013, 04:44 PM
zambezi Heres what I did. Not sure if it added any struct... Aug 18 2013, 11:54 AM
Larry Hubby If you've ever looked at the floor of the fron... Aug 18 2013, 06:01 PM
sean_v8_914 if anyone has evidence of stresses in this area, p... Aug 18 2013, 07:58 PM
Racer Chris This car had the full trunk floor intact.
Cracks o... Aug 19 2013, 07:37 AM
Eric_Shea :agree: I've seen pictures of a bad bushing li... Aug 19 2013, 08:56 AM
sean_v8_914 right along th spot weld line Aug 19 2013, 10:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 6th March 2026 - 09:58 PM |
