> Help needed: 75 1.8 won't start with key;, Will start when push-started
PBC914
post Aug 19 2013, 07:48 AM
I have a 75 1.8 that won't start. It was running and starting fine. I went for a short trip and came back to the car and it wouldn't start. The starter did not run.
Nothing has been changed in the wiring.
Car will start when push-started.
Ground strap is attached.
Test light glows when attached wires are tested at the starter.
Tried a new starter didn't make a difference.
Fuses look good.
Any ideas would be helpful! Thanks.
Paul
timothy_nd28
post Aug 19 2013, 09:08 AM
Bum information. If you pull the yellow wire, it won't have any voltage. You will need to probe either terminal 2 or 4 on the relay board, with the ignition in the start position.
If no voltage is on either terminal, pull the 14 connector on the relay board. Now check pin one on the wired connector for voltage. If still no voltage present, then you need to find the seat belt interlock circuit, which is under the passenger seat. Take a picture of this after you have found it and post it on here.
- Lo-Fi Version Time is now: 14th March 2026 - 12:06 PM
