| worn |
Aug 16 2013, 09:22 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,555 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
You may remember me from posts like the squid that ate my transmission. I built an engine and have pretty much solved various problems like leaks and oil pressure and oil temp. It is a 2056 with a 73 web cam + 2.5°.
I had to do some work on the heads. I was shooting for about a little over 8:1 compression, and while I have some uncertainty of deck height I am certain of the head chamber volume all matched to 69 cc ( I would say milliliters). According to CB Performance that would give me a maximum of 8.4 compression. That is the set up here is the problem. On load I hear a ticking sound, with maybe a tinkling high tone. There are several alternative sources of rattling, but it is coming from the engine bay. The gas here is generally 91 octane. I have enriched the MPS to deliver A/F to around 11:1 at load with part throttle and that has not cured the problem. After break in the car turned more difficultly with the starter so I wonder if the cam may be producing better dynamic compression. The heads overheat if I push air down the road at 70 - they generally don't at 50. Timing is stock. Question 1. Is this knock/ping/pink(UK)? Question 2. What are my best options and how quickly must they be instituted. The car is grounded for now. 3 - Thanks! |
| r_towle |
Aug 16 2013, 04:39 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
What distributor?
What fuel source? What carbs? What is the setup on the carbs? |
| worn |
Aug 19 2013, 09:47 AM
What distributor? What fuel source? What carbs? What is the setup on the carbs? Thanks to everyone that chipped in. I love my 914 but was ready to stop driving it indefinitely. But we thought we would back off the timing. I have an adjustable timing light -sometimes it even works. Odd. The mark at 27 degrees BDC shows up at idle, and when you rev the car it doesn't change - it sort of looks like it moves but only a degree or two. So I swapped in the distributor from the 1.7 with a pertronix trigger. Ping is gone. Wrong dizzy for the car, but the ping is not intrinsic to acceleration any more. There ought to be a big thanks banner that you can add from the cute little icons, but in the absence of such i shout: THANKS!!! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/piratenanner.gif) Now to rebuild a dizzy or find a better one. |
worn everyone knows Aug 16 2013, 09:22 AM
worn :idea: :popcorn: Aug 16 2013, 01:35 PM
kg6dxn The pinging, overheating and hard start is indicit... Aug 16 2013, 01:36 PM
worn
The pinging, overheating and hard start is indici... Aug 16 2013, 04:35 PM
worn
What distributor?
What fuel source? What carbs? W... Aug 16 2013, 08:41 PM
messix the engine most likely does not need as much ... Aug 16 2013, 08:19 PM
john rogers I would say the problem is the D-Jet system. Unles... Aug 16 2013, 08:47 PM
stugray Any chance you "upgraded" the oil pump d... Aug 18 2013, 01:32 PM
worn
Any chance you "upgraded" the oil pump ... Aug 19 2013, 09:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 03:40 AM |
