| PBC914 |
Aug 19 2013, 07:48 AM
Member ![]() ![]() Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
I have a 75 1.8 that won't start. It was running and starting fine. I went for a short trip and came back to the car and it wouldn't start. The starter did not run.
Nothing has been changed in the wiring. Car will start when push-started. Ground strap is attached. Test light glows when attached wires are tested at the starter. Tried a new starter didn't make a difference. Fuses look good. Any ideas would be helpful! Thanks. Paul |
| PBC914 |
Aug 19 2013, 08:48 AM
Thanks for the reply-the seatbelt interlock has not been touched.
I will check the yellow wire at the relay board. Anything else this could be? |
| r_towle |
Aug 19 2013, 10:40 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Thanks for the reply-the seatbelt interlock has not been touched. I will check the yellow wire at the relay board. Anything else this could be? Seat belt logic circuit was a 74 only thing, but you may have one. It started early in the year, and ended late from what I have seen. See if you have what looks like a relay under the passenger seat, if so, remove and jumper the two large yellow wires together. If not, Check with a helper to see if you have power at the starter (yellow wire spade bit) when you crank the motor. If not, start by cleaning the positive terminal at the battery, all the small RED wires. They get corroded enough to make this happen. If you still get no power at the starter when the key is turned to start, its the ignition switch most likely. Its a pretty simple circuit. Red line feeds the ignition switch from the battery... Yellow feeds the starter solenoid. rich |
PBC914 Help needed: 75 1.8 won't start with key; Aug 19 2013, 07:48 AM
timothy_nd28 Test light will glow on certain terminals on the s... Aug 19 2013, 07:58 AM
timothy_nd28 Lets start at the yellow wire and work backwards. ... Aug 19 2013, 08:54 AM
timothy_nd28 Bum information. If you pull the yellow wire, it ... Aug 19 2013, 09:08 AM
Rockaria The Ignition switch on a 914 is notorious for crac... Aug 19 2013, 09:59 AM
Outbackskip
The Ignition switch on a 914 is notorious for cra... Aug 19 2013, 01:54 PM
PBC914 Thanks everyone-I am heading over to work on the c... Aug 19 2013, 12:05 PM
Jeff Bowlsby The seatbelt interlock circuits were in all 1974-7... Aug 19 2013, 02:04 PM
r_towle
The seatbelt interlock circuits were in all 1974-... Aug 19 2013, 02:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 12:09 PM |
