gunny |
Member ![]() ![]() Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States ![]() |
I have had problems with High oil temps (240f) since I have owned the car when if I hit the highway for any period of time. It appears that I'm not able to cool the oil when at higher RPMs (above 3000) and the out side air is not cold. I have read every post that comes up in a search about oil flow and temp.
My car 1. 1976 2.0 D Jet cal with cat, pump and other extras removed 2. 20w50 oil 3. car runs very good and smooth (I don't have any other 914s to compare to) 4. idal good and steady(1100 cool, 950 warm) 5. no oil leaks (IMG:style_emoticons/default/aktion035.gif) I have added the following gages to better monitor this problem 1. Oil temp gage 2. Oil pressure gage (pressure >70psi at initial start, goes down to about 15 at idal and oil temp about 200, when oil tem goes higher pressur goes lower than 10 psi per 1000 rmp) 3. wideband 02 (12.5-13 at steady speed, goes down to about 10 at WOT for a few seconds then climbs to 11+ untill steady speed then about 12.5) (will go high 14+ for about 1 second at WOT while passing thru 3700 RPMs then back down to 12.5) I have checked or done the following work 1. adjusted/varified the valves, timeing , dwell, TPS 2. Injectors cleaned and flow tested (made motor run much better and smoother) 3. MPS hold vacuum 4. I have done all of the ECU Ohms checks 5. I have varified that my flap is coming down and covering the Oil cooler 6. I have no debris on the cooler or air flow to the oil cooler 7. I have all of the tins on the car, I have the 2 plastic air dams under the car 8. The fan is not missing any blades but does still have the pump pulley atached(I plan on removing when I take the motor out) 9. I have installed the higher oil relief spring and valve (problem did not change) 10. I have learned a lot about D-Jet theory 11. I'm still having fun but would like to be able to drive it more Any other suggestions would be appreaciated. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
I'd drop #6 off the list and just get the right parts and put'er back together.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I'd drop #6 off the list and just get the right parts and put'er back together. (IMG:style_emoticons/default/agree.gif) Aside from being aircooled, they are oil cooled and fuel cooled. So, the oil cooler needs to do its job with proper air flow. You can position the flap to always be putting the most air into that cooler...you like in the desert. For fuel, these cars are designed to run rich, it helps keep the motor cool. Timing and a slightly rich mixture, along with proper air flow will hopefully solve this. Acorns and nests are just all part of the pleasure of an aircooled car. rich |
Lo-Fi Version | Time is now: 26th August 2025 - 09:41 PM |
