| PBC914 |
Aug 19 2013, 07:48 AM
Member ![]() ![]() Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
I have a 75 1.8 that won't start. It was running and starting fine. I went for a short trip and came back to the car and it wouldn't start. The starter did not run.
Nothing has been changed in the wiring. Car will start when push-started. Ground strap is attached. Test light glows when attached wires are tested at the starter. Tried a new starter didn't make a difference. Fuses look good. Any ideas would be helpful! Thanks. Paul |
| Rockaria |
Aug 19 2013, 09:59 AM
ZippidyDoDah... ![]() ![]() ![]() Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
The Ignition switch on a 914 is notorious for cracking and breaking causing this exact problem. Works one second come out and it does not. Mine got worse if the car was outside in direct sunlight.
Pelicanparts - Replacing the 914 Ignition Switch Also, sometimes I would have problems with the starter not working after a hot drive. It was the wires at the starter. An add on starter relay at the starter can also help fix that problem. In a pinch I could use a long screwdriver at the starter to jump it (SAFTEY ISSUE: Don't try this unless you know what the heck you are doing. Make sure the car is in neutral and the brakes are on.) But if you swapped starters and it still would not work, I would check the ignition switch. I hope this helps, |
| Outbackskip |
Aug 19 2013, 01:54 PM
Newbie ![]() Group: Members Posts: 14 Joined: 13-December 11 From: Gassel, The Netherlands Member No.: 13,893 Region Association: Germany |
The Ignition switch on a 914 is notorious for cracking and breaking causing this exact problem. Works one second come out and it does not. Mine got worse if the car was outside in direct sunlight. Pelicanparts - Replacing the 914 Ignition Switch Also, sometimes I would have problems with the starter not working after a hot drive. It was the wires at the starter. An add on starter relay at the starter can also help fix that problem. In a pinch I could use a long screwdriver at the starter to jump it (SAFTEY ISSUE: Don't try this unless you know what the heck you are doing. Make sure the car is in neutral and the brakes are on.) But if you swapped starters and it still would not work, I would check the ignition switch. I hope this helps, Hi there, I had the exact same problem, ther was nothing wrong with the ignition switch but I lost too much power in the wiring from the ignition switch to the starter. Installing an extra relais at the starter solved the problem for me and the little teener has been starting perfectly for the last 2 years. Hope this helps, CU Later, Skip |
PBC914 Help needed: 75 1.8 won't start with key; Aug 19 2013, 07:48 AM
timothy_nd28 Test light will glow on certain terminals on the s... Aug 19 2013, 07:58 AM
PBC914 Thanks for the reply-the seatbelt interlock has no... Aug 19 2013, 08:48 AM
r_towle
Thanks for the reply-the seatbelt interlock has n... Aug 19 2013, 10:40 AM
timothy_nd28 Lets start at the yellow wire and work backwards. ... Aug 19 2013, 08:54 AM
timothy_nd28 Bum information. If you pull the yellow wire, it ... Aug 19 2013, 09:08 AM
PBC914 Thanks everyone-I am heading over to work on the c... Aug 19 2013, 12:05 PM
Jeff Bowlsby The seatbelt interlock circuits were in all 1974-7... Aug 19 2013, 02:04 PM
r_towle
The seatbelt interlock circuits were in all 1974-... Aug 19 2013, 02:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 12:11 PM |
