914-6 factory air cleaner - vs - K&N's, Which unit performs best |
david63 |
Aug 21 2013, 08:36 PM
Member Group: Members Posts: 96 Joined: 9-August 09 From: Parker Colorado Member No.: 10,653 Region Association: Rocky Mountains |
Currently have a factory 914-6 air cleaner on the 3.0 in my 74 conversion. Question for the group is which system breathes better, the factory system or the K&N filters? I like the look of the two filters with the watershields but if the factoy system is better performance wise I guess I should stick with it? Please advise.
monkeyboy |
Aug 23 2013, 07:50 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Actually, the K&N's filter better when dirty. All that crud in there makes the pore size smaller. You are supposed to run them until they start loosing flow. You can use a vacuum gauge to check flow resistance.
Needless, I will not run one without and Outerwears over it. They just pass too much dirt. I come from a off road backround, and I have seen motors "sanded" by a K&N. Also, the ones on my ATV's tend to shrink at the rubber bases. According to K&N, they do not like the smog in the air. |
Lo-Fi Version | Time is now: 6th June 2024 - 04:30 PM |
