ugh - electrical gremlins crop up!, worse than ever after cleaning the grounds! |
tadink |
Aug 28 2013, 05:00 PM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
Hey all -
73 1.7L FI in a 1971 tub, installed by McMark. While driving today - I depressed the brake pedal and had the tach, gas go to zero, and the red ALT light light up. Release brake, gas / tach return to normal. Depressing the brake pedal provides NO BRAKE LIGHTS, so that is bad. Turning on headlamps, operation normal. Turning on turn signals - tach and gas drop to zero, no turn signals. No Hazards - but that has been going on for some time. Prior to this - turning on the turn signals lit up the big red light as the switch flickered, but it also did produce turn signals. Not any more. When going over bumps - red ALT light flickers, when low RPM red light begins to glow, goes dark with higher RPMs. Also - when driving today on the freeway after 45mins at high speed, developed a little stutter, not bad, almost un-noticable, not all the time. possibly not related - dunno. (IMG:style_emoticons/default/confused24.gif) ugh, I hate the elec shit. (IMG:style_emoticons/default/hissyfit.gif) where to start oh great and wise brain trust.....????? thanks in advance.... td |
tadink |
Aug 28 2013, 05:06 PM
damn, not only are you guys good, you're FAST!
I'll go look - will advise. td |
Elliot Cannon |
Aug 28 2013, 06:24 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
damn, not only are you guys good, you're FAST! I'll go look - will advise. td SLITS is good. Just not as fast he thought he was. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 10:02 AM |
