ugh - electrical gremlins crop up!, worse than ever after cleaning the grounds! |
tadink |
Aug 28 2013, 05:00 PM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
Hey all -
73 1.7L FI in a 1971 tub, installed by McMark. While driving today - I depressed the brake pedal and had the tach, gas go to zero, and the red ALT light light up. Release brake, gas / tach return to normal. Depressing the brake pedal provides NO BRAKE LIGHTS, so that is bad. Turning on headlamps, operation normal. Turning on turn signals - tach and gas drop to zero, no turn signals. No Hazards - but that has been going on for some time. Prior to this - turning on the turn signals lit up the big red light as the switch flickered, but it also did produce turn signals. Not any more. When going over bumps - red ALT light flickers, when low RPM red light begins to glow, goes dark with higher RPMs. Also - when driving today on the freeway after 45mins at high speed, developed a little stutter, not bad, almost un-noticable, not all the time. possibly not related - dunno. (IMG:style_emoticons/default/confused24.gif) ugh, I hate the elec shit. (IMG:style_emoticons/default/hissyfit.gif) where to start oh great and wise brain trust.....????? thanks in advance.... td |
sean_v8_914 |
Aug 29 2013, 07:32 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
before i get into chasing ghosts I like to do a system clean up. this kills many common problems like voltage drop when pressing teh brake pedal
clean teh chassis ground above teh fuse panel clean the fuses with a scotch brite pad. only rub in one direction so you dont rip the metal tab off clean fuse panel fuse holding tabs clean chassis ground in engine compartment next to relay board clean relay board contacts and things that connect to it clean chassis ground strap and attachment points on transaxle and under trunk floor after 40 years , they all need this. |
Spoke |
Aug 29 2013, 08:01 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
before i get into chasing ghosts I like to do a system clean up. this kills many common problems like voltage drop when pressing teh brake pedal clean teh chassis ground above teh fuse panel clean the fuses with a scotch brite pad. only rub in one direction so you dont rip the metal tab off clean fuse panel fuse holding tabs clean chassis ground in engine compartment next to relay board clean relay board contacts and things that connect to it clean chassis ground strap and attachment points on transaxle and under trunk floor after 40 years , they all need this. (IMG:style_emoticons/default/agree.gif) Excellent preventive maintenance advice. |
Lo-Fi Version | Time is now: 8th June 2024 - 11:41 PM |
