> Spongy brakes, 914-4 brakes won't firm up??!
Gearren
post Jul 19 2004, 04:59 AM
I've had it! I have done everything to the brakes on my car, and I can't seem to get them to stop the car with authority. Best I get is a reluctant coast to a stop. Hardly suitable for street use! I have owned the 73 2.0 since new, and have kept it in the garage since 85. Brakes have always been weak, so as I starterd on the quest to revive the car, the brakes were top on the list. I have rebuilt both front and rear calipers, turned the rotors, new pads, new M/C (17mm), bled the m/c, bled the prop valve, and bled the system at least 10 times! I still have weak/spongy brakes! I want to keep the car stock, however I am tempted to remove the prop valve to see if it is the culprit. Any ideas or suggestions would be appreciated??
ArtechnikA
post Jul 19 2004, 05:39 AM
rich herzog
didn't see that you adjusted the parking brake venting clearance; it's critical to good pedal feel. the value published in the Haynes manual is not correct - it's aty least twice too big.
if the venting clearance is too large it will really show up with the sstock 17mm master cylinder. many people mistake the slightly longer pedal travel and increased sensitivity for being spongy. it is possible to use the 911/914.6 19mm master cylinder if everything else has been done correctly and you still don't like the feel.
914's hydraulic system is hard to get bled properly, and the proportioner valve is a major culprit. i don't recommend removing them in an otherwise stock car with otherwise stock brakes, but i know that a lot of people do,
i have used a lot of bleeding techniques and now i've pretty much settled into pressure bleeding while at home and close to the airsource, and using the SpeedBleeder bleedscrews at the track. make sure you're using good fluid -- lots of people alternate between Ate Super Blue and Gold so they can tell at a glance when flushing is complete; i like Valvoline SynPower fluid. just make sure it's a reputable DOT 4 fluid from a fresh container and IMO - especially since you are experiencing sponginess - avoid silicone.
Gearren   Spongy brakes   Jul 19 2004, 04:59 AM
ArtechnikA   didn't see that you adjusted the parking brake...   Jul 19 2004, 05:39 AM
smg914   I'm not saying I recommend you remove the prop...   Jul 19 2004, 09:06 AM
seanery   If the car has been sitting, the rubber lines coul...   Jul 19 2004, 09:15 AM
SLITS   :agree: Change the rubber brake lines and see wh...   Jul 19 2004, 09:21 AM
davep   :agree: I use new rubber lines, a 19mm master, a...   Jul 19 2004, 11:07 AM
Gearren   I neglected to say that I did set the venting clea...   Jul 19 2004, 01:46 PM
ArtechnikA   <...   Jul 19 2004, 01:54 PM
lapuwali   Pad material can make a significant difference. ...   Jul 19 2004, 01:59 PM
seanery   :agree: with james.   Jul 19 2004, 02:02 PM
davep   The early stainless lines were not DOT. They tende...   Jul 19 2004, 02:11 PM
tat2dphreak   I did not see this mentioned (though I did just "s...   Jul 19 2004, 02:13 PM
mike_the_man   I'm in about the same boat as you. I would re...   Jul 19 2004, 02:20 PM
Eric_Shea   I have a couple good proportioning valves if you w...   Jul 19 2004, 02:28 PM
Gearren   I guess my plan of attack is to readjust the venti...   Jul 19 2004, 03:21 PM
phantom914   Why hasn't anyone recommended specific pads? I...   Jul 19 2004, 04:02 PM
ArtechnikA
- Lo-Fi Version Time is now: 6th July 2025 - 01:26 PM
