> Spongy brakes, 914-4 brakes won't firm up??!
Gearren
post Jul 19 2004, 04:59 AM
I've had it! I have done everything to the brakes on my car, and I can't seem to get them to stop the car with authority. Best I get is a reluctant coast to a stop. Hardly suitable for street use! I have owned the 73 2.0 since new, and have kept it in the garage since 85. Brakes have always been weak, so as I starterd on the quest to revive the car, the brakes were top on the list. I have rebuilt both front and rear calipers, turned the rotors, new pads, new M/C (17mm), bled the m/c, bled the prop valve, and bled the system at least 10 times! I still have weak/spongy brakes! I want to keep the car stock, however I am tempted to remove the prop valve to see if it is the culprit. Any ideas or suggestions would be appreciated??
smg914
post Jul 19 2004, 09:06 AM
Sahara Beige Steve
I'm not saying I recommend you remove the proportioner valve but I can tell you that I replaced the valve with the "T" connector on my old 914-4 race car and the 914-6 race car and various 914 street cars over the years with nothing but positive results.
I would start with the parking brake venting clearance and if you are still not happy, then remove the proportioner valve.
Gearren   Spongy brakes   Jul 19 2004, 04:59 AM
ArtechnikA   didn't see that you adjusted the parking brake...   Jul 19 2004, 05:39 AM
smg914   I'm not saying I recommend you remove the prop...   Jul 19 2004, 09:06 AM
seanery   If the car has been sitting, the rubber lines coul...   Jul 19 2004, 09:15 AM
SLITS   :agree: Change the rubber brake lines and see wh...   Jul 19 2004, 09:21 AM
davep   :agree: I use new rubber lines, a 19mm master, a...   Jul 19 2004, 11:07 AM
Gearren   I neglected to say that I did set the venting clea...   Jul 19 2004, 01:46 PM
ArtechnikA   <...   Jul 19 2004, 01:54 PM
lapuwali   Pad material can make a significant difference. ...   Jul 19 2004, 01:59 PM
seanery   :agree: with james.   Jul 19 2004, 02:02 PM
davep   The early stainless lines were not DOT. They tende...   Jul 19 2004, 02:11 PM
tat2dphreak   I did not see this mentioned (though I did just "s...   Jul 19 2004, 02:13 PM
mike_the_man   I'm in about the same boat as you. I would re...   Jul 19 2004, 02:20 PM
Eric_Shea   I have a couple good proportioning valves if you w...   Jul 19 2004, 02:28 PM
Gearren   I guess my plan of attack is to readjust the venti...   Jul 19 2004, 03:21 PM
phantom914   Why hasn't anyone recommended specific pads? I...   Jul 19 2004, 04:02 PM
ArtechnikA
- Lo-Fi Version Time is now: 6th July 2025 - 01:40 PM
