| Mblizzard |
Aug 25 2013, 07:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Well I think I have most of my engine sorted. Still some fine tuning on the carbs to go. But today when I was driving I noticed that at speed a slight back and forth motion of the wheel seems to set up a swaying pattern that could get out of control easily. To quote Jeremy Clarkson of Top Gear "at one point a little bit of poo came out."
I installed some used but still very good boge shocks. I have plans to replace the rubber bushings on the torsion bars but I am really concerned that something else is wrong. Nothing looks wrong but I am sure that the ball joints could be worn but I have never experienced that type of sway that seemed to want to get out of control. Thoughts on what to change or check? |
| Mblizzard |
Sep 2 2013, 06:03 PM
Finally got back to this. Did the various checks on the wheels. All seemed good without any excessive travel. Looks like it is either the control arm bushings or McMarks suggestion.
Did not get to that tonight but it is next. Got set if control arms coming with the sway bar tabs. But I doubt I can get the ball joints swapped out without damaging them so it may have to wait if it is not the steering bushing. |
Mblizzard Front suspension sucks Aug 25 2013, 07:03 PM
7275914911 Steering Rack Bolts have come loose or come out? C... Aug 25 2013, 07:06 PM
Mblizzard
Steering Rack Bolts have come loose or come out? ... Aug 25 2013, 07:13 PM
r_towle Bearings. Aug 25 2013, 07:06 PM
Mblizzard
Bearings.
Checked bearings and there was no rea... Aug 25 2013, 07:11 PM
Drums66 ....Bearings as stated above or lug bolt torque :... Aug 25 2013, 07:17 PM
Mblizzard
....Bearings as stated above or lug bolt torque ... Aug 25 2013, 07:24 PM
r_towle Jack up on front wheel, leave the other on the gro... Aug 25 2013, 07:19 PM
Spoke Front end out of alignment may make the car seem t... Aug 25 2013, 07:21 PM
HalfMoon
Front end out of alignment may make the car seem ... Aug 26 2013, 09:52 PM
Drums66 ......Yes.that body sway
:wavebye:(frontend) Aug 25 2013, 07:36 PM
Mblizzard
:wavebye:(frontend)
I... Aug 25 2013, 07:48 PM
McMark Also, the 'bushing' between the steering c... Aug 25 2013, 08:44 PM
FourBlades Check everything in front and rear suspension and ... Aug 25 2013, 08:46 PM
rhodyguy did the car do this prior to the boge install? too... Aug 26 2013, 07:51 AM
Mblizzard
did the car do this prior to the boge install? to... Aug 26 2013, 08:04 AM
Shindog1961 Did anyone mention tie rods? Mine rolls a lot when... Aug 26 2013, 09:33 PM
Jeffs9146 When you loosen the 3 bolts that hold the out side... Aug 26 2013, 10:54 PM
HalfMoon
When you loosen the 3 bolts that hold the out sid... Aug 26 2013, 11:11 PM
Dave_Darling
When you loosen the 3 bolts that hold the out sid... Aug 27 2013, 07:39 AM
cwpeden WAIT! Warning before you get someone to attem... Aug 26 2013, 11:10 PM
HalfMoon
WAIT! Warning before you get someone to atte... Aug 26 2013, 11:12 PM
Mblizzard Well I have a list of things to check tonight... Aug 27 2013, 07:47 AM
scott_in_nh
Well I have a list of things to check tonight... Aug 27 2013, 08:24 AM
Steve Pelican has stock rubber ones Aug 27 2013, 08:36 AM
McMark You can also stack two VW ones. See this thread. Aug 27 2013, 09:30 AM
Jeffs9146 When I put my 5-lug suspension on and drove it for... Aug 27 2013, 10:31 AM
Mblizzard Did not get to the front end checks tonight but I ... Aug 27 2013, 07:06 PM
Mblizzard Well after checking everything and it seeming good... Sep 13 2013, 01:54 PM
Cupomeat
Well after checking everything and it seeming goo... Sep 13 2013, 03:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:30 AM |
