| Krieger |
Sep 3 2013, 08:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,847 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
I had an old fashioned Hot Lap timer in my car this past weekend and had problems with it. Actually other people had the same inconsistencies. I was looking at a Droid App by Trackmaster. Does video and lap times, speed.
| SirAndy |
Sep 5 2013, 12:39 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The problem with GPS is that at it's best it has about 1m (3 feet) spread. At it's worst, it can be 50 or more meters (well over a 100 feet).
So, the weaker your signals are at the track, the less accurate a GPS based system will be. (IMG:style_emoticons/default/shades.gif) |
| Matt Romanowski |
Sep 8 2013, 04:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
The problem with GPS is that at it's best it has about 1m (3 feet) spread. At it's worst, it can be 50 or more meters (well over a 100 feet). So, the weaker your signals are at the track, the less accurate a GPS based system will be. (IMG:style_emoticons/default/shades.gif) They end up very accurate. For instance, an AiM Solo is usually within .001 of the official AMB loop. I'm not sure about other systems, but AiM also tells you how many satellites the system has locked onto and what the accuracy is. I used to make the same argument and once I started using a GPS based system, I found out how good they really are. |
Krieger Lap timer apps for droid Sep 3 2013, 08:42 PM
Woody Harry's lap timer just recently became availab... Sep 4 2013, 05:19 AM
Krieger Thanks Woody Ill check it out! Sep 4 2013, 07:56 AM
jeff http://aimsports.com/
I have this setup on my kart... Sep 4 2013, 08:56 AM
ThePaintedMan I have Trackmaster on my phone and it's well w... Sep 4 2013, 09:55 AM
r_towle how are these things getting a signal from a base ... Sep 4 2013, 06:47 PM
ThePaintedMan
how are these things getting a signal from a base... Sep 4 2013, 07:29 PM
Krieger I think they use GPS. The Trackmaster is cheap an... Sep 4 2013, 07:27 PM
Woody An external Bluetooth GPS reciever is recommend fo... Sep 4 2013, 07:34 PM
ThePaintedMan
An external Bluetooth GPS reciever is recommend f... Sep 4 2013, 07:53 PM
r_towle Start and stop at our autox is in different places... Sep 4 2013, 08:01 PM
Woody
Start and stop at our autox is in different place... Sep 4 2013, 08:42 PM
ThePaintedMan
They end up very accurate. For instance, an AiM ... Sep 9 2013, 10:00 PM
SirAndy At least that's how I understand it all.
:D... Sep 9 2013, 11:27 PM
ThePaintedMan
I actually work with this stuff on a daily basis... Sep 10 2013, 08:10 AM
r_towle I recall that the 3 foot accuracy was just recentl... Sep 5 2013, 05:10 AM
ThePaintedMan See if this works for you guys, but this is what a... Sep 10 2013, 08:20 AM
Matt Romanowski :confused: I'm not a GPS expect, but have 1,00... Sep 10 2013, 09:33 AM
wobbletop The GPS units also add things like sector times, c... Sep 10 2013, 10:44 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:24 PM |
