brake pedal to the floor?, Brake warning light on the dash works correctly |
malcolm2 |
Sep 8 2013, 07:20 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have never had the car off of jack stands. Rebuilt all 4 calipers, pedal cluster & installed a fresh 17mm MC and 4 new flex brake lines. Set the venting clearance on the rear brakes and the pedal clearance is also good.
Bleeding the brakes I get good fluid movement and no air bubbles from all 4 corners. Probably have been around the car 10 times now. The last 2 times around were the best as far as no air and lots of fluid per pump...using my wife to press the pedal. Rear brakes grab and hold. I cannot move them by hand. Front brakes now grab, but with just a bit of extra work I can move the rotor with my wife holding the brake pedal down. My pedal is not firm and does bottom out. Then if the key is on, the dash warning light flashes at the bottom. Is that how it works? the main question here: But why do I still have a weak pedal and little or no front brakes? Do I just need to get it moving and operate the brakes? Thanks, Clark |
Mblizzard |
Sep 9 2013, 05:44 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Another dumb question but I have let air back in at times when bleeding the open valve way. Do you use a hose one the bleeder and insert the other end in a clear jar of fluid? I thought I was done many times only to have this method show more air.
malcolm2 |
Sep 9 2013, 09:31 AM
Another dumb question but I have let air back in at times when bleeding the open valve way. Do you use a hose one the bleeder and insert the other end in a clear jar of fluid? I thought I was done many times only to have this method show more air. Yes, Barely crack the bleeder, and use a 1/2 full jar. Only way air can get in is by the threads of the bleeder. I also made a few rounds using the tire valve on the fluid res. cap. I could not watch the bleedings, so I went back to ask the wife to work the pedal. |
Lo-Fi Version | Time is now: 11th June 2024 - 02:05 PM |
