brake pedal to the floor?, Brake warning light on the dash works correctly |
malcolm2 |
Sep 8 2013, 07:20 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have never had the car off of jack stands. Rebuilt all 4 calipers, pedal cluster & installed a fresh 17mm MC and 4 new flex brake lines. Set the venting clearance on the rear brakes and the pedal clearance is also good.
Bleeding the brakes I get good fluid movement and no air bubbles from all 4 corners. Probably have been around the car 10 times now. The last 2 times around were the best as far as no air and lots of fluid per pump...using my wife to press the pedal. Rear brakes grab and hold. I cannot move them by hand. Front brakes now grab, but with just a bit of extra work I can move the rotor with my wife holding the brake pedal down. My pedal is not firm and does bottom out. Then if the key is on, the dash warning light flashes at the bottom. Is that how it works? the main question here: But why do I still have a weak pedal and little or no front brakes? Do I just need to get it moving and operate the brakes? Thanks, Clark |
Bob L. |
Sep 9 2013, 07:31 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
perhaps you have a small leak somewhere else in the system. New flex lines, master cylinder? All connections tight?
I would check the fluid level in reservoir, pump the pedal hard several times and recheck the fluid level. see if it is dropping. Seek your leak if it is. |
malcolm2 |
Sep 9 2013, 07:38 PM
perhaps you have a small leak somewhere else in the system. New flex lines, master cylinder? All connections tight? I would check the fluid level in reservoir, pump the pedal hard several times and recheck the fluid level. see if it is dropping. Seek your leak if it is. Yes new everything but the hard lines. I see no fluid at any connection. Not in the tunnel, around the MC, the pressure thing in the engine compartment, calipers, no leaks or wet-ness. |
Bob L. |
Sep 9 2013, 07:55 PM
perhaps you have a small leak somewhere else in the system. New flex lines, master cylinder? All connections tight? I would check the fluid level in reservoir, pump the pedal hard several times and recheck the fluid level. see if it is dropping. Seek your leak if it is. Yes new everything but the hard lines. I see no fluid at any connection. Not in the tunnel, around the MC, the pressure thing in the engine compartment, calipers, no leaks or wet-ness. Did you check the floor under the MC, behind the pedal board? |
malcolm2 |
Sep 9 2013, 08:04 PM
Lo-Fi Version | Time is now: 12th June 2024 - 12:03 AM |
