martinef1963 |
The Saga Continues... ![]() ![]() Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States ![]() |
![]() The install of the ring of the VDO sensor is held in by the #3 cylinder sparkplug to engine case - while R&Ring the sparkplug that ring gets beat up and access to it with the tin is a real pain in the.... If one splices the wire to positive on the FI sensor, does the sensor not ground itself to the engine and send signal to VDO gauge? Or do you still need the negative feed back to the gauge. Just asking. thanks, Fern |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
Initial resistances are all wrong, but if you are witty enough you could make anything work
Lo-Fi Version | Time is now: 8th July 2025 - 09:21 PM |
