> Engine Cylinder Heat Sensor, Modification?
martinef1963
post Sep 11 2013, 07:13 PM
The Saga Continues...
Attached ImageHello to all. I have never read on the site, not that it hasn't been discussed - the use of the FI engine cylinder heat sensor being used on VDO gauge for a car that has been converted to carbs.
The install of the ring of the VDO sensor is held in by the #3 cylinder sparkplug to engine case - while R&Ring the sparkplug that ring gets beat up and access to it with the tin is a real pain in the....
If one splices the wire to positive on the FI sensor, does the sensor not ground itself to the engine and send signal to VDO gauge? Or do you still need the negative feed back to the gauge. Just asking.
thanks,
Fern
martinef1963
post Sep 12 2013, 05:44 PM
I wanted to thank all that commented. The link (German Supply) is very useful, don't know if it bothers me that much to pull the engine at this moment, heck I got to get it running first. If I had to in the future will definitely use the method on the link. Thanks again.
Fern
- Lo-Fi Version Time is now: 8th July 2025 - 09:28 PM
