Cylinder heads for 1.8, replace, fix, or upgrade? |
Hine62 |
Sep 11 2013, 02:36 PM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
When we tuned up the valve gaps I noticed that one of my exhaust ports studs was fixed using a heli-coil. Of course that coil needed to be replace because it pulled out, then when tightening the other side of the same port I noticed the hole the stud was in was cracked, and of course it broke. I tired JB weld but that didn't work.
So my question is... can this problem be fixed, or should the heads be replaced (new or used?), or is there an upgraded head? I'm assuming the engine will need to be pulled out to take the heads off. |
ldsgeek |
Sep 13 2013, 12:16 PM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
Not sure if the hardware is that bad, but I think the valves and ports are sized for the bus engine rather than the 914 version, meaning it will run but run out of steam at the top end.
Lo-Fi Version | Time is now: 6th June 2024 - 08:42 PM |
