Cylinder heads for 1.8, replace, fix, or upgrade? |
Hine62 |
Sep 11 2013, 02:36 PM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
When we tuned up the valve gaps I noticed that one of my exhaust ports studs was fixed using a heli-coil. Of course that coil needed to be replace because it pulled out, then when tightening the other side of the same port I noticed the hole the stud was in was cracked, and of course it broke. I tired JB weld but that didn't work.
So my question is... can this problem be fixed, or should the heads be replaced (new or used?), or is there an upgraded head? I'm assuming the engine will need to be pulled out to take the heads off. |
r_towle |
Sep 12 2013, 08:52 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Www.aircooled.net has them.
400 bucks each..cheaper than fixing your. Rich |
Bob L. |
Sep 13 2013, 12:46 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 6th June 2024 - 11:50 PM |
