Cylinder heads for 1.8, replace, fix, or upgrade? |
Hine62 |
Sep 11 2013, 02:36 PM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
When we tuned up the valve gaps I noticed that one of my exhaust ports studs was fixed using a heli-coil. Of course that coil needed to be replace because it pulled out, then when tightening the other side of the same port I noticed the hole the stud was in was cracked, and of course it broke. I tired JB weld but that didn't work.
So my question is... can this problem be fixed, or should the heads be replaced (new or used?), or is there an upgraded head? I'm assuming the engine will need to be pulled out to take the heads off. |
Dave_Darling |
Sep 13 2013, 09:37 AM
Note that the new AMC heads from Spain have decent castings, but not so great hardware. The general procedure with them is to replace pretty much everything but the basic casting when using them. I don't remember if the seats and guides were part of the stuff that should be replaced, but I wouldn't be surprised if they are.
--DD |
r_towle |
Sep 13 2013, 10:46 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Note that the new AMC heads from Spain have decent castings, but not so great hardware. The general procedure with them is to replace pretty much everything but the basic casting when using them. I don't remember if the seats and guides were part of the stuff that should be replaced, but I wouldn't be surprised if they are. --DD Just curious. Have there been documented cases of failures of the new heads, bolted on right out of the box? Rich |
Dave_Darling |
Sep 13 2013, 04:02 PM
Have there been documented cases of failures of the new heads, bolted on right out of the box? I don't know. Len Hoffman was one person I recall saying that the included hardware wasn't up to snuff. He may have documented cases, or he may have simply looked at what was on the heads and decided it was unsuitable. You'd have to ask him. --DD |
Lo-Fi Version | Time is now: 7th June 2024 - 06:41 AM |
