Cylinder heads for 1.8, replace, fix, or upgrade? |
Hine62 |
Sep 11 2013, 02:36 PM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
When we tuned up the valve gaps I noticed that one of my exhaust ports studs was fixed using a heli-coil. Of course that coil needed to be replace because it pulled out, then when tightening the other side of the same port I noticed the hole the stud was in was cracked, and of course it broke. I tired JB weld but that didn't work.
So my question is... can this problem be fixed, or should the heads be replaced (new or used?), or is there an upgraded head? I'm assuming the engine will need to be pulled out to take the heads off. |
stugray |
Sep 15 2013, 02:46 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE They fit in large flat rate box! $15 x2 = 30 much cheaper. Post office? UPS office? |
Lo-Fi Version | Time is now: 6th June 2024 - 06:35 PM |
