> Engine Seems To Run Hot, Even on cool days
Mblizzard
post Sep 15 2013, 04:18 PM
Ok so I have been driving my new 2056 with dual webers an a SVDA dizzy with electronic ignition. Timing is set at 30 btdc. It seems like when I am on the interstate the temp gauge seems to ride at about 75% of the way toward hot.
The flaps should be set correctly and the thermostat seems to be allowing the flaps to move completely. As it moves toward hot I notice a lot of pinging.
Plugs don't seem to be running hot or lean by looking at them. I am going to look at the flaps with my scope to verify the position but what to check after that?
rhodyguy
post Sep 16 2013, 09:41 AM
mike, have you verified that the cooling flaps are indeed fully opening when at temp?
k
Mblizzard   Engine Seems To Run Hot   Sep 15 2013, 04:18 PM
JimN73   On my car, 3/4 of the way to the red part is only ...   Sep 15 2013, 04:51 PM
eyesright   I agree that the IR thermometer is a good investme...   Sep 15 2013, 06:00 PM
Mblizzard   Good point! Ordered one. Will check temps. ...   Sep 15 2013, 06:39 PM
r_towle   Good point! Ordered one. Will check temps. ...   Sep 15 2013, 06:54 PM
dlee6204   Any thoughts on pinging? Reduce advance? Yes,...   Sep 15 2013, 06:50 PM
Krieger   Reduce the advance a few degrees or get higher oct...   Sep 15 2013, 07:01 PM
Mikey914   SOunds kind of basic, but check the fan. Reach bac...   Sep 16 2013, 09:29 AM
r_towle   also, don't forget the gauges are kinda , sort...   Sep 16 2013, 09:37 AM
Mblizzard   also, don't forget the gauges are kinda , sor...   Sep 16 2013, 12:43 PM
r_towle   also, don't forget the gauges are kinda , so...   Sep 16 2013, 12:46 PM
rhodyguy   mike, have you verified that the cooling flaps are...   Sep 16 2013, 09:41 AM
Mblizzard   mike, have you verified that the cooling flaps ar...   Sep 16 2013, 12:45 PM
Mblizzard   Did a little checking and based on the PET, while ...   Sep 16 2013, 03:03 PM
Racer Chris   Did a little checking and based on the PET, while...   Sep 21 2013, 05:19 AM
r_towle   My point is that the gauges are not super accurate...   Sep 16 2013, 04:12 PM
Mblizzard   Ok so,after reducing the timing to 27 and a couple...   Sep 20 2013, 07:34 PM
timothy_nd28   Which dizzy do you have?   Sep 20 2013, 07:40 PM
Mblizzard   Which dizzy do you have? SVDA Hotspark. I have...   Sep 20 2013, 07:43 PM
Mblizzard   Chris - no AF gauge. I don't think I am runnin...   Sep 21 2013, 06:26 AM
Racer Chris   Chris - no AF gauge. I don't think I am runni...   Sep 21 2013, 07:52 AM
- Lo-Fi Version Time is now: 16th June 2024 - 07:29 PM
