Confused again- Frothy Oil, after installing new oil pump and front cooler |
tornik550 |
Sep 16 2013, 06:33 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I just started my engine after installing a new oil pump and front oil cooler. Everything seems to be running fine however when I stopped the engine to check the oil level- I noticed a borborygmi type sound from the from of the engine for a few seconds. Checked my oil level and the oil was very frothy.
Oil pressure was great, no oil leaks, everything seems to be running fine. The car had been sitting for about 2 weeks while I was installing the new cooler. The oil level is normal. I did not have any oil in the hoses to the front cooler whcih is why I am checking my oil level closely since it will obviously drop once the thermostat opens. FYI- My new setup uses a schadek 30mm pump (yes it was modified), mocal sandwich plate with built in thermostat, rx7 front cooler via AN12 braided stainless hose. I used Brad Penn 20w50 oil however there was probably a quart of Amsoil 20w50 (high zinc) oil already in. What causes the frothy oil? |
bandjoey |
Sep 16 2013, 07:13 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I was told it's from the oil not getting hot enough on short trips to burn off he water vapor (condensation?) . I used to drive a 5 mile trip to work and it was there. Later a 30 mile trip to work daily and never saw it again.
Lo-Fi Version | Time is now: 7th June 2024 - 03:46 AM |
