| nolift914 |
Sep 17 2013, 06:36 PM
Autoxer ![]() ![]() Group: Members Posts: 186 Joined: 24-May 09 From: Rockaway Beach NY Member No.: 10,399 Region Association: None |
Is my Autox 914 too stiff?
I am currently running the PO setup, the 914 was set up for club racing with front and rear coil overs. The front is at 330lbs/in which I believe is the equivalent to 25MM torsion bars and the rear is at 230. The 914 is a 4 weighting approx 1780lbs with bias ply slicks. I plan on switching to Dot-R radials. I have always thought for autox go soft on springs and big on bars. Does the paddock crowd have any suggestions for a setup. The autox sites in NYC tend to be on the rough side. I was thinking either 175 lbs/in in front and 140 lbs/in rear or 200 lbs/in front and 180 lbs/in rear. |
| nolift914 |
Sep 18 2013, 03:26 PM
Is my Autox 914 too stiff? I am currently running the PO setup, the 914 was set up for club racing with front and rear coil overs. The front is at 330lbs/in which I believe is the equivalent to 25MM torsion bars and the rear is at 230. The 914 is a 4 weighting approx 1780lbs with bias ply slicks. I plan on switching to Dot-R radials. I have always thought for autox go soft on springs and big on bars. Does the paddock crowd have any suggestions for a setup. The autox sites in NYC tend to be on the rough side. I was thinking either 175 lbs/in in front and 140 lbs/in rear or 200 lbs/in front and 180 lbs/in rear. Currently running 19mm torsion bars with a smart racing bar, with the smallest diameter bar they offered. Had under-steer until I went to the lightest smart racing bar. Front shocks are Koni's set to almost total soft. Rear springs are 240# if I remember correctly. They might be #225, but will check. With Avon's no under-steer at autox's or hilllclimbs. I'm 100# ligher than you. Are you going to Dot-radials to make a class? I am currently running in PCA class M01 and SCCA FP, I am looking to move away from the Canti's due to the limited availability. Cant find soft compounds. Going to either Radial slicks or Dot-R autox tires. I found this chart listing the front torsion bar spring rate SIZE ( mm) SPRING RATE ( Lb/in) 18.8 110 21 173 22 210 23 250 24 296 25 350 I believe I have 330lbs / springs on the front which by the chart would be the equivalent to 24.5mm bar, which seems stiffer than those listed in this thread from 19mm to 21mm. There are some mine fields with a suspension set up like I related.. A stiff shassis is needed to *make the suspension do its work*......I'm talkin' bridge stiff. A stock chassis will flex all over hell and make handling inconsistent. To help the suspension do its work, low friction bushings....not cheep derlin/poly whatever, are needed. Over 200 lb rear springs can/will cause cracking aound the un-reinforced rear towers long term.....the rougher the venue, the quicker this happens. Enjoy (IMG:style_emoticons/default/biggrin.gif) J P I should have given more details of the 914's current setup, In addition to the front and rear coil-overs on Bilsteins, the front struts have raised spindles. front and rear Elephant racing polybronze bearings, Reinforced rear trailing arms and lower console, full 8 point cage. no reinforcement on front and rear shock towers. Front sway bar (Weltmeister) and no rear bar. From the setup's listed everyone is softer in front between 125lbs to 175lbs and stiffer in the back 225 to 275. (IMG:style_emoticons/default/confused24.gif) |
| mskala |
Sep 18 2013, 04:43 PM
R ![]() ![]() ![]() Group: Members Posts: 1,935 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
I believe your chart is accurate from my memory of 21mm calculation.
Anyway, what do I know, I've never driven anything other than the 914 in anger, but here is my opinion. Yes, you should have the front softer or equal springs to rear. Since your car is not a street car, overall stiffer is better, except when the surface gets too bad. Understeer is not your friend, and can be tuned a bit with the front bar. Also, unless you have a co-driver, with such a light car it may be difficult to heat up the tires if you go with something wide for your semi-flares. We do a group of 4 runs and the first 2 for me are only for heating. If lucky the pressure goes up by ~4psi then I know I'm in business (with dot-r). Here is my setup, which I'm pretty happy with as a street car. Torsion bar: 20mm (yes, these are occasionally available) Rear spring: 180 Front sway: 19mm weltmeister, set kinda in the middle after tuning Rear sway: none Front shock: koni adj Rear shock: Bilstein non-adj (perch adjustable) Wavetrac limited slip about -2deg camber all over lowered slightly, no spindle change Wheel: 7.5x16 Fuchs-center, BBS rim Tire: Kumho V710 215/40/16 No flares Weight: stock but no tar on interior (~2050) Engine: 2.2L 'E' six |
nolift914 Autox Spring rate help Sep 17 2013, 06:36 PM
Randal
I am currently running... Sep 17 2013, 09:23 PM
J P Stein MY 914 weighed 1700 to 1780 lbs depending on balla... Sep 18 2013, 06:00 AM
Woody My current AX setup is similar to what JP used to ... Sep 18 2013, 06:18 AM
J P Stein There are some mine fields with a suspension set ... Sep 18 2013, 07:56 AM
nolift914
I believe your chart is accurate from my memory o... Sep 18 2013, 05:24 PM
Randal Right, no soft compounds with Canti's.
Befor... Sep 19 2013, 10:21 AM
nolift914
Befo... Sep 19 2013, 11:47 AM
Randal
Bef... Sep 19 2013, 09:47 PM
J P Stein There are several spring rate for torsion bar char... Sep 18 2013, 07:53 PM
J P Stein R35 Hoosiers always worked for me. There was most ... Sep 19 2013, 12:27 PM
nolift914
R35 Hoosiers always worked for me. There was most... Sep 19 2013, 12:48 PM
Downunderman With 330 on the front and 230 on the back the thin... Sep 19 2013, 01:29 PM
Racer Chris
With 330 on the front and 230 on the back the thi... Sep 20 2013, 04:56 AM
J P Stein Next time some expert tells you what spring rate y... Sep 20 2013, 08:53 AM
nolift914 I guess my question is what spring rate is equival... Sep 20 2013, 09:03 AM
J P Stein Looking at the supplied chart the answer would 21m... Sep 21 2013, 08:05 AM
nolift914
Looking at the supplied chart the answer would 21... Sep 22 2013, 08:41 AM
mskala
I have been AutoX for 25 years but the last 15 ha... Sep 22 2013, 03:04 PM
Randal
Looking at the supplied chart the answer would 2... Sep 22 2013, 07:16 PM
Randal Speaking of research, have you asked Tom Provasi h... Sep 21 2013, 08:42 AM
Woody :agree: Sep 22 2013, 04:22 PM
J P Stein First let me say there are MAYBE 6-8 truly fast 91... Sep 23 2013, 07:22 AM
nolift914 Lesson learned, do not reply to a post after 14hr ... Sep 25 2013, 07:43 AM
Randal
Lesson learned, do not reply to a post after 14hr... Sep 25 2013, 08:25 PM
J P Stein Coil overs intrude on the space for tires.
Using s... Sep 25 2013, 09:31 AM
J P Stein When administrating the "butt test", I w... Sep 26 2013, 09:53 AM
nolift914
When administrating the "butt test", I ... Sep 27 2013, 08:00 AM
Racer Chris
I am retaining the 230lb rear springs and goi... Sep 27 2013, 10:31 AM
J P Stein
I am retaining the 230lb rear springs and go... Sep 27 2013, 12:12 PM
nolift914
[quote name='Racer Chris' post='1932693' date='Se... Nov 12 2013, 07:32 AM
Woody Awesome. Did you get a video? Nov 12 2013, 09:27 AM
nolift914
The battery in my ... Nov 12 2013, 03:07 PM
ChrisNPDrider OMG isn't it always about the tires? <_... Nov 13 2013, 10:45 AM
nolift914
OMG isn't it always about the tires? <_... Nov 13 2013, 02:55 PM
sean_v8_914 lots of great recommendations from very experience... Nov 15 2013, 01:19 PM
nolift914
lots of great recommendations from very experienc... Nov 15 2013, 07:16 PM
Woody
lots of great recommendations from very experien... Nov 15 2013, 07:53 PM
Randal
[quote name='nolift914' post='1957411' date='Nov ... Nov 16 2013, 10:55 AM
dlestep Use charts as reference to get yourself in the nei... Nov 16 2013, 01:15 PM
Randal
If you think tires are important, try asking som... Nov 16 2013, 01:29 PM
Woody I don't run with any of you so this is what I ... Nov 16 2013, 02:39 PM
Randal
I don't run with any of you so this is what I... Nov 16 2013, 02:58 PM
Woody
I don't run with any of you so this is what ... Nov 16 2013, 07:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th December 2025 - 02:29 AM |
