| Mark Henry |
Sep 20 2013, 02:31 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Over the winter I'd like to repair my dad's canoe. I know it looks bad, but the main skin is kevlar, the woodwork is cedar and fairly simple, plus there is enough bits to copy. I have the tools, my trade is cabinetmaking. Only thing missing to copy is the yoke, but the old one sucked anyways
The kevlar repairs will be the only thing hard-ish to do and this is where the question comes in.... Can I cut this in half and add 3 feet to the center? It's a 15-1/2' canoe and it's looking like I need a 3 person canoe. If the wife was into it I'd get another canoe, but if it's just me and the 2 kids I'd rather have just one canoe. Most 3 person canoes are 18-19 feet. Any tips would be welcome (IMG:style_emoticons/default/smile.gif) Attached image(s)
| Mike Bellis |
Sep 20 2013, 03:10 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Kevlar is almost like fiberglass and uses the same techniques. I would be a little concerned with the structural integrity after adding 3 feet..
That is probably a vacuum molded product. Very hard to duplicate in the garage. You could build a buck and layer it on old school style. It will not be as smooth or as thin but should work. How concerned with looks are you? |
| Mark Henry |
Sep 20 2013, 09:18 PM
By the looks of that thing you might be better off getting one of the beach assualt landing crafts that the Marines use. (IMG:style_emoticons/default/idea.gif) Seriously that thing is done. I know it looks bad but the woodwork is the easy part, all pretty simple stuff. I would have to make forms for the ribs and a steam box for the bending, but it's not as hard as one may think. The material cost to repair the holes and wood (without the extension) would be only be a couple hundred dollars and 4-5 Sundays. I have most of the wood needed, just what ever the epoxy costs. Kevlar is almost like fiberglass and uses the same techniques. I would be a little concerned with the structural integrity after adding 3 feet.. That is probably a vacuum molded product. Very hard to duplicate in the garage. You could build a buck and layer it on old school style. It will not be as smooth or as thin but should work. How concerned with looks are you? I only care about function and that it's light. This canoe weighed 48 lbs. when new. The ribs give it the structure, the broken ribs why it looks so warped. |
Mark Henry WOT: Dad's kevlar canoe major repair/rebuild Sep 20 2013, 02:31 PM
914forme
Kevlar is almost like fiberglass and uses the sam... Sep 20 2013, 07:25 PM
warpig By the looks of that thing you might be better off... Sep 20 2013, 07:30 PM
JRust Only a 914 guy would rebuild that >:D . Most se... Sep 20 2013, 11:09 PM
Mark Henry
Only a 914 guy would rebuild that >:D . Most s... Sep 21 2013, 07:14 AM
balljoint Rebuild it. Don't Frankenstein it and add to t... Sep 21 2013, 07:42 AM
Mark Henry
Eastern cedar over western for strength and fib... Sep 21 2013, 12:17 PM
barefoot Disagree with prior post. Epoxy is easy to work w... Sep 21 2013, 07:48 AM
Mark Henry
Disagree with prior post. Epoxy is easy to work ... Sep 21 2013, 12:11 PM
r_towle We built them high school with a mold, but no vacu... Sep 21 2013, 10:25 AM
r_towle Wallpaper steamer rented does a great job. Sep 21 2013, 03:29 PM
Mark Henry Man.....I should buy and finish this and just repa... Sep 22 2013, 07:20 AM
kg6dxn
Man.....I should buy and finish this and just rep... Sep 22 2013, 10:24 AM
Mark Henry
[quote name='Mark Henry' post='1929964' date='Sep... Sep 22 2013, 11:15 AM
r_towle Part of training them for canoe camping is portage... Sep 22 2013, 06:06 PM
Mark Henry
Part of training them for canoe camping is portag... Sep 22 2013, 06:58 PM
balljoint You have your less than and greater than signs rev... Sep 22 2013, 07:43 PM
Mark Henry
You have your less than and greater than signs re... Sep 23 2013, 06:00 AM
Joe Sharp Mike: The Kern River requires portage. Sep 23 2013, 05:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th April 2026 - 12:53 AM |
