| nolift914 |
Sep 17 2013, 06:36 PM
Autoxer ![]() ![]() Group: Members Posts: 186 Joined: 24-May 09 From: Rockaway Beach NY Member No.: 10,399 Region Association: None |
Is my Autox 914 too stiff?
I am currently running the PO setup, the 914 was set up for club racing with front and rear coil overs. The front is at 330lbs/in which I believe is the equivalent to 25MM torsion bars and the rear is at 230. The 914 is a 4 weighting approx 1780lbs with bias ply slicks. I plan on switching to Dot-R radials. I have always thought for autox go soft on springs and big on bars. Does the paddock crowd have any suggestions for a setup. The autox sites in NYC tend to be on the rough side. I was thinking either 175 lbs/in in front and 140 lbs/in rear or 200 lbs/in front and 180 lbs/in rear. |
| Randal |
Sep 21 2013, 08:42 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Speaking of research, have you asked Tom Provasi how he had the car set up when it was a big autox winner?
nolift914 Autox Spring rate help Sep 17 2013, 06:36 PM
Randal
I am currently running... Sep 17 2013, 09:23 PM
J P Stein MY 914 weighed 1700 to 1780 lbs depending on balla... Sep 18 2013, 06:00 AM
Woody My current AX setup is similar to what JP used to ... Sep 18 2013, 06:18 AM
J P Stein There are some mine fields with a suspension set ... Sep 18 2013, 07:56 AM
nolift914
[quote name='nolift914' post='1927965' date='Sep ... Sep 18 2013, 03:26 PM
mskala I believe your chart is accurate from my memory of... Sep 18 2013, 04:43 PM
nolift914
I believe your chart is accurate from my memory o... Sep 18 2013, 05:24 PM
Randal Right, no soft compounds with Canti's.
Befor... Sep 19 2013, 10:21 AM
nolift914
Befo... Sep 19 2013, 11:47 AM
Randal
Bef... Sep 19 2013, 09:47 PM
J P Stein There are several spring rate for torsion bar char... Sep 18 2013, 07:53 PM
J P Stein R35 Hoosiers always worked for me. There was most ... Sep 19 2013, 12:27 PM
nolift914
R35 Hoosiers always worked for me. There was most... Sep 19 2013, 12:48 PM
Downunderman With 330 on the front and 230 on the back the thin... Sep 19 2013, 01:29 PM
Racer Chris
With 330 on the front and 230 on the back the thi... Sep 20 2013, 04:56 AM
J P Stein Next time some expert tells you what spring rate y... Sep 20 2013, 08:53 AM
nolift914 I guess my question is what spring rate is equival... Sep 20 2013, 09:03 AM
J P Stein Looking at the supplied chart the answer would 21m... Sep 21 2013, 08:05 AM
nolift914
Looking at the supplied chart the answer would 21... Sep 22 2013, 08:41 AM
mskala
I have been AutoX for 25 years but the last 15 ha... Sep 22 2013, 03:04 PM
Randal
Looking at the supplied chart the answer would 2... Sep 22 2013, 07:16 PM
Woody :agree: Sep 22 2013, 04:22 PM
J P Stein First let me say there are MAYBE 6-8 truly fast 91... Sep 23 2013, 07:22 AM
nolift914 Lesson learned, do not reply to a post after 14hr ... Sep 25 2013, 07:43 AM
Randal
Lesson learned, do not reply to a post after 14hr... Sep 25 2013, 08:25 PM
J P Stein Coil overs intrude on the space for tires.
Using s... Sep 25 2013, 09:31 AM
J P Stein When administrating the "butt test", I w... Sep 26 2013, 09:53 AM
nolift914
When administrating the "butt test", I ... Sep 27 2013, 08:00 AM
Racer Chris
I am retaining the 230lb rear springs and goi... Sep 27 2013, 10:31 AM
J P Stein
I am retaining the 230lb rear springs and go... Sep 27 2013, 12:12 PM
nolift914
[quote name='Racer Chris' post='1932693' date='Se... Nov 12 2013, 07:32 AM
Woody Awesome. Did you get a video? Nov 12 2013, 09:27 AM
nolift914
The battery in my ... Nov 12 2013, 03:07 PM
ChrisNPDrider OMG isn't it always about the tires? <_... Nov 13 2013, 10:45 AM
nolift914
OMG isn't it always about the tires? <_... Nov 13 2013, 02:55 PM
sean_v8_914 lots of great recommendations from very experience... Nov 15 2013, 01:19 PM
nolift914
lots of great recommendations from very experienc... Nov 15 2013, 07:16 PM
Woody
lots of great recommendations from very experien... Nov 15 2013, 07:53 PM
Randal
[quote name='nolift914' post='1957411' date='Nov ... Nov 16 2013, 10:55 AM
dlestep Use charts as reference to get yourself in the nei... Nov 16 2013, 01:15 PM
Randal
If you think tires are important, try asking som... Nov 16 2013, 01:29 PM
Woody I don't run with any of you so this is what I ... Nov 16 2013, 02:39 PM
Randal
I don't run with any of you so this is what I... Nov 16 2013, 02:58 PM
Woody
I don't run with any of you so this is what ... Nov 16 2013, 07:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th December 2025 - 02:29 AM |
