> WOT: Dad's kevlar canoe major repair/rebuild, Any kevlar repair guru's? A few questions
Mark Henry
post Sep 20 2013, 02:31 PM
that's what I do!
Over the winter I'd like to repair my dad's canoe. I know it looks bad, but the main skin is kevlar, the woodwork is cedar and fairly simple, plus there is enough bits to copy. I have the tools, my trade is cabinetmaking. Only thing missing to copy is the yoke, but the old one sucked anyways
The kevlar repairs will be the only thing hard-ish to do and this is where the question comes in....
Can I cut this in half and add 3 feet to the center?
It's a 15-1/2' canoe and it's looking like I need a 3 person canoe. If the wife was into it I'd get another canoe, but if it's just me and the 2 kids I'd rather have just one canoe. Most 3 person canoes are 18-19 feet.
Any tips would be welcome (IMG:style_emoticons/default/smile.gif)
r_towle
post Sep 21 2013, 10:25 AM
Custom Member
We built them high school with a mold, but no vacuum.
You will need to make a mold to get the middle shape correct, but it should work.
You will need to make a female mold, then lay the canoe right side up into the mold.
So the mold might be 5 or 6 feet long to help you line it up.
Use plywood bucks, and 1/4 inch plywood screwed into the bucks.
Then sand that, and lay two coats of fiberglass on the inside of that mold.
Sand, fill, paint with epoxy paint, but and wax that mold.
Then you lay everything together and mold you fiberglass on the inside while overlapping into both halves.
Let it set, and put your new gunnels in place, then relapse from the mold.
Then flip it over and finish the other side with new Kevlar to make the bottom smooth.
Rich
Mark Henry   WOT: Dad's kevlar canoe major repair/rebuild   Sep 20 2013, 02:31 PM
kg6dxn   Kevlar is almost like fiberglass and uses the same...   Sep 20 2013, 03:10 PM
914forme   Kevlar is almost like fiberglass and uses the sam...   Sep 20 2013, 07:25 PM
Mark Henry   By the looks of that thing you might be better of...   Sep 20 2013, 09:18 PM
warpig   By the looks of that thing you might be better off...   Sep 20 2013, 07:30 PM
JRust   Only a 914 guy would rebuild that >:D . Most se...   Sep 20 2013, 11:09 PM
Mark Henry   Only a 914 guy would rebuild that >:D . Most s...   Sep 21 2013, 07:14 AM
balljoint   Rebuild it. Don't Frankenstein it and add to t...   Sep 21 2013, 07:42 AM
Mark Henry   Eastern cedar over western for strength and fib...   Sep 21 2013, 12:17 PM
barefoot   Disagree with prior post. Epoxy is easy to work w...   Sep 21 2013, 07:48 AM
Mark Henry   Disagree with prior post. Epoxy is easy to work ...   Sep 21 2013, 12:11 PM
r_towle   We built them high school with a mold, but no vacu...   Sep 21 2013, 10:25 AM
r_towle   Wallpaper steamer rented does a great job.   Sep 21 2013, 03:29 PM
Mark Henry   Man.....I should buy and finish this and just repa...   Sep 22 2013, 07:20 AM
kg6dxn   Man.....I should buy and finish this and just rep...   Sep 22 2013, 10:24 AM
Mark Henry   [quote name='Mark Henry' post='1929964' date='Sep...   Sep 22 2013, 11:15 AM
r_towle   Part of training them for canoe camping is portage...   Sep 22 2013, 06:06 PM
Mark Henry   Part of training them for canoe camping is portag...   Sep 22 2013, 06:58 PM
balljoint   You have your less than and greater than signs rev...   Sep 22 2013, 07:43 PM
Mark Henry   You have your less than and greater than signs re...   Sep 23 2013, 06:00 AM
Joe Sharp   Mike: The Kern River requires portage.   Sep 23 2013, 05:54 AM
- Lo-Fi Version Time is now: 4th April 2026 - 12:51 AM
