| 914itis |
Sep 21 2013, 01:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I am tryng to bench start my 6 with carbs. I have fuel but no sparks.
I check the points and they are opening and closing. All grounds are connected. Positive is applied the positive side of the coil. The only thing I am not sure how to chck is the cd box. As far as I can tell the c box is powered from the positive side of the coil. help! |
| DEC |
Sep 21 2013, 06:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany
You can't test the CD box without any special test equipment
If you don't hear a whistle from the CD box the box is not connected correct or is defect. |
| 914itis |
Sep 21 2013, 10:13 PM
914itis Hot wiring a 914-6 / 911 engine Sep 21 2013, 01:17 PM
SLITS 3 pin
A = + or 15, coil hot primary terminal ( - ... Sep 21 2013, 03:43 PM
r_towle If you put a condenser inline, you can remove the ... Sep 21 2013, 03:55 PM
914itis Here is what I did.
I hot wire the coil by groun... Sep 21 2013, 04:11 PM
Eric_Shea Plug it in. If you hear a high pitch whine, it... Sep 21 2013, 06:05 PM
larryM based on what you say above, you have the wiring a... Sep 22 2013, 12:20 AM
914itis Thanks, ground was not connected on Cdi box starte... Sep 22 2013, 05:45 AM
jimkelly now that is a happy ending :D Sep 22 2013, 07:45 AM![]() ![]() |
Lo-Fi Version | Time is now: 20th December 2025 - 07:34 PM |
