Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
I don't want to hijack someone else's thread so here we are.
Yes! I read Dr. Evil's notes. After making an adjustment to the shift linkage I lost 1st gear during a test drive. At the start of the drive it was fine getting into 1st. Sometimes a bit crunchy but "normal" Then, after a few miles and several "stop & go's" ... stopped at a light... it turns green... go for 1st, aaand rejected. I tried a few tugs on the shifter and it was like a solid barrier. I went to 2nd and took it home. On the way I stopped a few times and tried 1st when I had opportunity. 1 time it went in with a good amount of shoving. That was last week. Now after some tinkering with the linkage and replacing the shift rod U-joint bushings, it still wouldn't get 1st. I went directly to the shifter console and I have the same problem. In and forward for 1st, Right? I can get all other gears without issue. During my "exam" this morning I was able to get 1st once with much jiggling and shoving. Once I took it out of 1st, it didn't want to go back. There is plenty of tranny fluid. I don't know what? looks pretty clean. Well there we are. I really don't want to pull the trans. Help!... again...please... |
TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
I didnt read the other thread, but have you tried shifting gears directly at the trans? This will tell you if it is a linkage issue, or maybe something internal.
Lo-Fi Version | Time is now: 3rd September 2025 - 01:22 AM |
