> Finally driving again!, Type IV CIS conversion
dlee6204
post Jul 17 2011, 09:39 PM
Howdy
I finally got to drive my 914 again! (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/biggrin.gif) Back in June I was having fits with the L-Jet system that was on my car so I decided it was time to tackle a project I was wanting to do for some time, a CIS conversion.
I retrofitted a CIS Basic system to my stock 1.8L engine using parts from various VWs and Mercedes and today I fired it up for the first time and was able to take it for a long drive. It felt AWESOME. Smooth reliable power all the way to redline. It has a nice growl to it too. (IMG:style_emoticons/default/evilgrin.gif) I'm quite impressed. I still have to make some small adjustments but at least now I can get back to driving the car daily and the best part, NO MORE JACKSTANDS! I'm going to drive the snot out of the car this week to get the system dialed in and hopefully next weekend I will take it for a day drive in the mountains. (IMG:style_emoticons/default/driving.gif) More details and pics to come later.
The cat is happy too!
jaxdream
post Sep 24 2013, 09:56 PM
This has been a great thread to follow . I have a question about the injector retention methods shown here , sequence - o ring, spacer, larger o ring , washer, clamp - correct ?? and this does hold / keep the injector seated into the injector cavity even with the hi pressure that they run under , also does the hole at the end of the injector get covered or uncovered. Gotta ask if you don't know / haven't experienced.
Jack
type47
post Sep 25 2013, 05:52 AM
Viermeister
QUOTE(jaxdream @ Sep 24 2013, 07:56 PM) *
yes, in fact, the most left "o-ring" is a D-Jet injector small seal. There are 2 washers used.
we haven't fired this up but I think the arrangement will hold up to the high injector pressure. It's pretty secure. The holes you refer to are the 4 small holes on the side? They are not covered up. Of course the hole at the end of the injector is free, that's the business end. I/we haven't run this particular engine yet to see if everything will be a success but plan to try at the ECC Oct 12. The motor is out of the car for testing and adjustment. I have a header exhaust, no muffler, that was on the engine when it was a race (PCA club racing) car. This cis system eliminates the ECU, MPS, decel valve, trigger points in the distributor, air cleaner assembly, throttle position sensor
dlee6204   Finally driving again!   Jul 17 2011, 09:39 PM
rick 918-S   :popcorn: I always thought CIS off a VW Rabbit wou...   Jul 17 2011, 09:43 PM
Prospectfarms   :headbanger: Great idea and congratulations. I...   Jul 17 2011, 09:47 PM
kg6dxn   Were's all the pictures from the build?   Jul 17 2011, 10:30 PM
Vacca Rabite   Information please! Zach   Jul 18 2011, 06:07 AM
ripper911   Smokey wants more pictures! http://www.914worl...   Jul 18 2011, 06:24 AM
BKLA   CIS ='CALICO IS SLEEPING' ??? :)   Jul 18 2011, 08:11 AM
Jake Raby   CIS works great on TIV engines.. I had the set up ...   Jul 18 2011, 08:39 AM
Cap'n Krusty   CIS? Would that be "Cat In Situ"? The ...   Jul 18 2011, 08:51 AM
rwilner   you guys are nuts...I don't let the cats on my...   Jul 18 2011, 08:57 AM
ripper911   you guys are nuts...I don't let the cats on m...   Jul 18 2011, 01:09 PM
montoya 73 2.0   I am working on the same thing except from what Ri...   Jul 18 2011, 01:05 PM
dlee6204   Okay here is a break down of everything I used. ...   Jul 18 2011, 09:27 PM
dlee6204   For the injectors I had to fab up some brackets a...   Jul 18 2011, 09:29 PM
dlee6204   And finally since I was completely new to anything...   Jul 18 2011, 09:32 PM
dlee6204   Oh and the cat is 18 years old and a HUGE 914 fan ...   Jul 18 2011, 09:36 PM
montoya 73 2.0   One of these Volvo 240 Aluminum Air Box Tray's...   Jul 18 2011, 09:44 PM
dlee6204   Yeah I need to do something about that. I had t...   Jul 18 2011, 09:47 PM
montoya 73 2.0   Jeffs914/6 was or is installing CIS on his 3.0. V...   Jul 18 2011, 09:53 PM
ThinAir   I was drooling over Dan & Jeff Dixon's CIS...   Jul 18 2011, 10:37 PM
dflesburg   whats with the long pipe on the air box? Why didn...   Jul 19 2011, 07:28 AM
dlee6204   Link saved! Thanks! The Rabbit I got m...   Jul 19 2011, 08:30 AM
dlee6204   The pipe goes from the Fuel Distributor/Airbox t...   Jul 19 2011, 08:33 AM
scotty b   I would think CIS would also be great as the basic...   Jul 19 2011, 01:15 PM
ArtechnikA   It's "basically" a mass-flow system ...   Jul 19 2011, 01:29 PM
Dr Evil   There has been proof that CIS actually does fine w...   Jul 19 2011, 03:55 PM
ArtechnikA   There has been proof that CIS actually does fine ...   Jul 19 2011, 04:37 PM
Dr Evil   There has been proof that CIS actually does fine...   Jul 19 2011, 06:04 PM
ArtechnikA   ...So, no need to arguetwasn't an argument. ...   Jul 19 2011, 07:19 PM
TargaToy   Ok, Jake says it's a good system. He's th...   Jul 19 2011, 08:10 PM
scotty b   Ok, Jake says it's a good system. He's t...   Jul 19 2011, 08:11 PM
Vacca Rabite   I have thought about CIS for my 2056, but have hel...   Jul 19 2011, 08:28 PM
scotty b   I have thought about CIS for my 2056, but have he...   Jul 19 2011, 08:33 PM
TargaToy   Is this hard to integrate with a stock ECU? What ...   Jul 19 2011, 08:43 PM
dlee6204   I just thought I would post some links that I foun...   Jul 19 2011, 09:21 PM
Prospectfarms   I'm not sure how that system would interface w...   Jul 19 2011, 09:31 PM
jcd914   I can't speak to the overlap limits with CIS (...   Jul 20 2011, 01:47 AM
Prospectfarms   Thanks Jim, I value your "narrative of experi...   Jul 20 2011, 06:56 AM
Rex-n-effect   My 81 Scirocco, daily driver, has 417,000 miles on...   Jul 20 2011, 08:51 AM
Rex-n-effect   I have to take that back. I had to replace the Lam...   Jul 20 2011, 09:01 AM
Jake Raby   Since the system is volume based it is imperative ...   Jul 20 2011, 09:14 AM
Vacca Rabite   Jake is your carb cam (the one similar to the 494)...   Jul 20 2011, 12:22 PM
rohar   Jake is your carb cam (the one similar to the 494...   Sep 2 2011, 09:56 PM
Vacca Rabite   Jake is your carb cam (the one similar to the 49...   Sep 3 2011, 05:15 PM
914_teener   [quote name='rohar' post='1533899' date='Sep 2 20...   Sep 24 2013, 10:44 PM
charliew   Jakes probably under a boxter looking for a oil le...   Jul 20 2011, 12:29 PM
ChrisNPDrider   Jakes probably under a boxter looking for a oil l...   Jul 21 2011, 08:57 AM
scotty b   Jakes probably under a boxter looking for a oil ...   Jul 21 2011, 08:18 PM
jaxdream   Maybe one could get some stainless lines made up f...   Jul 22 2011, 05:02 PM
jimkelly   curious? if one were to use a megajolt jr with ed...   Jul 22 2011, 08:28 PM
Prospectfarms   curious? if one were to use a megajolt jr with e...   Jul 22 2011, 09:27 PM
jcd914   [quote name='jimkelly' post='1513355' date='Jul 2...   Jul 23 2011, 12:15 AM
Prospectfarms   :confused: I've followed this thread hoping ...   Jul 22 2011, 09:16 PM
jcd914   :confused: I've followed this thread hoping...   Jul 23 2011, 12:12 AM
Prospectfarms   jcd914 wrote: "I put a 1.7L long block in a 7...   Jul 23 2011, 03:12 PM
rohar   ... I don't know where a stash of late 70...   Sep 2 2011, 10:30 PM
jaxdream   This mod would be a great alternative to buying a ...   Jul 23 2011, 07:27 AM
nein14   I can speak of it's reliability and performanc...   Jul 27 2011, 10:45 AM
dlee6204   A little update on this…. The car is running gr...   Aug 2 2011, 11:09 PM
jaxdream   Great :Qarl: , I was wanting to see an update on ...   Aug 3 2011, 08:30 AM
pete-stevers   great thread!!   Sep 2 2011, 09:31 PM
rohar   After sleeping on it, I could be convinced to go o...   Sep 3 2011, 12:20 PM
Dr Evil   Zach, for you I would gladly assemble a MSII for f...   Sep 3 2011, 07:24 PM
HAM Inc   As for what happens with a radical cam with the CI...   Sep 4 2011, 09:34 PM
dlee6204   Small Update: I've been driving the car alo...   Sep 11 2011, 07:15 PM
jaxdream   Most Excellllent :Qarl: :Qarl: !!!...   Sep 11 2011, 10:38 PM
SirAndy   Most Excellllent :Qarl: :Qarl: !!!...   Sep 11 2011, 10:59 PM
Vacca Rabite   That GREAT! Zach   Sep 12 2011, 05:11 AM
dlee6204   So I thought I would give one last quick update......   Nov 17 2011, 05:55 PM
Dr Evil   How cold? The cold start injector does not fire un...   Nov 17 2011, 07:12 PM
76-914   Doug, what do you think is a fair price for this s...   Nov 17 2011, 07:57 PM
dlee6204   I know the cold start injector fires around 32 ...   Nov 17 2011, 08:27 PM
dlee6204   I would say you could get most of the components...   Nov 17 2011, 08:33 PM
pete-stevers   i hope to build out my next 914 with a cis 1.7...r...   Nov 17 2011, 08:34 PM
Dion   Doug, Nice build. I have the CIS on my 2.0. It ...   Nov 18 2011, 10:56 AM
trojanhorsepower   Hey Doug, Looks good. Glad you got it worked out...   Nov 19 2011, 05:53 PM
Jeffs9146   I used the Volvo box in my 3.0L 6 conversion and...   Nov 19 2011, 06:24 PM
nein14   I used the Volvo box in my 3.0L 6 conversion an...   Nov 20 2011, 07:51 AM
Kraftwerk   Dion, I like that set up, and a very clean ins...   Nov 19 2011, 07:33 PM
type47   So, how did you guys transition from the boot on t...   Sep 16 2013, 02:25 PM
dlee6204   I ended up switching to a 2.0L intake and Throttle...   Sep 16 2013, 02:35 PM
dlee6204   RE: Finally driving again!   Sep 16 2013, 02:41 PM
type47   That's beautiful! I have a plastic "S...   Sep 16 2013, 02:50 PM
Dion   Nice work Jim, My set up is using PVC pipe ...   Sep 16 2013, 08:38 PM
type47   Thanks for the pix, Dion. I asked this ? before; d...   Sep 17 2013, 06:37 AM
914dave   Thanks for the pix, Dion. I asked this ? before; ...   Sep 17 2013, 01:39 PM
type47   I like your washer idea. That'll work just fi...   Sep 17 2013, 03:36 PM
rhodyguy   will second generation jetta etc, cis work as well...   Sep 17 2013, 06:48 AM
Dion   Hey Jim, Glad Dave responded to your question. D...   Sep 17 2013, 04:13 PM
type47   Found an even better way to mount the injectors. 1...   Sep 24 2013, 06:47 PM
914dave   Found an even better way to mount the injectors. ...   Sep 25 2013, 04:12 AM
jaxdream   This has been a great thread to follow . I have a ...   Sep 24 2013, 09:56 PM
type47   I have a question about the injector retention m...   Sep 25 2013, 05:52 AM
jaxdream   Thanks Jim , that was a great clarification , ment...   Sep 25 2013, 08:25 AM
type47   Progress is on schedule to try to fire this thing ...   Oct 2 2013, 04:24 PM
dlee6204   You shouldn't need an accumulator. I don...   Oct 2 2013, 05:15 PM
type47   :D http://www.youtube.com/watch?v=gRLyDnp7G_0   Oct 13 2013, 07:01 AM
jimkelly   stainless steel braided fuel lines of CIS is way c...   Oct 13 2013, 07:53 AM
Kraftwerk   Jim, enjoyed that film and the narration...   Oct 13 2013, 11:06 PM
- Lo-Fi Version Time is now: 27th June 2026 - 04:35 PM
