| Elliot Cannon |
Sep 24 2013, 03:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Could this leak be coming from a crack in the head at the valve guide?
| stugray |
Sep 27 2013, 11:04 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE there shouldn't be oil on the outside. If the valve guide is loose and leaking, that will cause higher than normal crankcase pressure as the exhaust gases blow by the guide into the head. Since he has a head vent directly over where we see the oil leaking down the header stub, I think that is the source of the oil on the outside of the stub. |
Elliot Cannon Oil leak Sep 24 2013, 03:12 PM
stugray My first thought was that there is nothing up ther... Sep 24 2013, 03:48 PM
SirAndy AND - B|tch slap whoever put all that sillycone on... Sep 24 2013, 04:05 PM
396 AND - B|tch slap whoever put all that sillycone on... Sep 24 2013, 04:12 PM
Elliot Cannon I ask for help and I get criticized. Sheesh. I f... Sep 24 2013, 09:24 PM
SLITS
I ask for help and I get criticized. Sheesh. I ... Sep 24 2013, 09:25 PM
Elliot Cannon OK, I'm pretty sure the inside of the exhaust ... Sep 25 2013, 02:19 PM
Dave_Darling :( I'd agree; time to pull that head and have... Sep 25 2013, 02:43 PM
r_towle could be headwork, could be junk rings.
Pull it, ... Sep 25 2013, 03:03 PM
Elliot Cannon
Pull it,... Sep 25 2013, 04:31 PM
stugray
The part that I was commenting on was the drip o... Sep 25 2013, 03:15 PM
Elliot Cannon
The part that I was commenting on was the drip ... Sep 25 2013, 04:34 PM
SLITS
So, which is better, carbs or fuel injection?
N... Sep 25 2013, 04:44 PM
Elliot Cannon
... Sep 25 2013, 10:40 PM
SLITS I would have told you that your guess at a crack v... Sep 25 2013, 04:37 PM
r_towle
I would have told you that your guess at a crack ... Sep 25 2013, 07:41 PM
Elliot Cannon
I would have told you that your guess at a crack... Sep 25 2013, 10:36 PM
Dave_Darling
... supervise you while you waited for the leprec... Sep 25 2013, 11:13 PM
Elliot Cannon
... supervise you while you waited for the lepre... Sep 26 2013, 10:34 AM
SLITS
[quote name='Dave_Darling' post='1932012' date='S... Sep 26 2013, 11:17 AM
Elliot Cannon
I would have told you that your guess at a crack ... Sep 25 2013, 10:32 PM
StratPlayer Time for a six elliot :beer1: Sep 25 2013, 08:14 PM
Elliot Cannon
I'm working on... Sep 25 2013, 10:37 PM
Dave_Darling I thought he was from the Coast, not from Vegas... Sep 26 2013, 04:17 PM
r_towle Guinness and scotch are not made from meat, right?... Sep 26 2013, 04:20 PM
Elliot Cannon OMG, I went to bed last night and the Leprechauns ... Sep 26 2013, 05:31 PM
r_towle Undercoating. Sep 26 2013, 05:48 PM
Elliot Cannon
Undercoating.
It will be painted with VHT. Work... Sep 26 2013, 10:20 PM
stugray nice job! I have said many times that you can ... Sep 26 2013, 08:19 PM
Elliot Cannon
nice job! I have said many times that you can... Sep 26 2013, 10:25 PM
Dave_Darling Inspect the head first. Look over it carefully to... Sep 26 2013, 10:40 PM
Elliot Cannon These valve guides just don't look right and m... Sep 26 2013, 10:42 PM
stugray
If you cant tell a :stir: :poke: when you see ... Sep 26 2013, 10:49 PM
Elliot Cannon
If you cant tell a :stir: :poke: when you see... Sep 26 2013, 10:56 PM
stugray The inside of those heads look too clean for some ... Sep 26 2013, 10:58 PM
Elliot Cannon
The inside of those heads look too clean for some... Sep 26 2013, 11:03 PM
stugray
Got it! I actually thought we had a pretty ... Sep 26 2013, 11:00 PM
Elliot Cannon
Got it! I actually thought we had a pretty... Sep 26 2013, 11:11 PM
stugray When I first said:
I didnt realize that you had... Sep 26 2013, 11:40 PM
Elliot Cannon Both head vents are connected to a breather and I ... Sep 27 2013, 12:00 AM
euro911 I would go through both heads. It will help to ass... Sep 27 2013, 01:37 AM
SLITS Most engines that use guides, the guide for the va... Sep 27 2013, 06:28 AM
bulitt Slits has it. The guide has moved in the head. Eit... Sep 27 2013, 06:45 AM
rhodyguy remove, straighten, and 'pretty up' the en... Sep 27 2013, 07:14 AM
lsintampa IDK,
If the valve guide were leaking, it would s... Sep 27 2013, 10:26 AM
914_teener I am with Mark......, Elliot....
I'd do both ... Sep 27 2013, 12:04 PM
Elliot Cannon
I'd do both... Sep 27 2013, 12:18 PM
SLITS You two should get a room.
Can I pick on you now ... Sep 27 2013, 01:31 PM
Elliot Cannon
Can I pick on you now... Sep 27 2013, 07:02 PM
r_towle It looks like it moved.
I would re-ring it, but th... Sep 27 2013, 02:01 PM
76-914 :poke: Damn Ron, you gonna let that "rela... Sep 27 2013, 04:57 PM
Elliot Cannon Mid-rise lift makes a good work bench. Sep 27 2013, 07:03 PM
Elliot Cannon I hope I remember how all this shit goes back toge... Sep 27 2013, 07:05 PM
Elliot Cannon Both the rocker arm assemblies are totally clean. ... Sep 27 2013, 07:07 PM
SLITS When you pull the rocker assemblies get 8 each 5/1... Sep 27 2013, 08:54 PM
Elliot Cannon
When you pull the rocker assemblies get 8 each 5/... Sep 27 2013, 11:50 PM
Eric_Shea
Paint the rest of it yellow... Sep 28 2013, 12:02 AM
euro911 I hope you tagged your push rods, and if you pull(... Sep 28 2013, 02:50 AM
SLITS
I hope you tagged your push rods, and if you pull... Sep 28 2013, 08:52 AM
Eric_Shea
So we've heard... <_< Sep 28 2013, 09:46 AM
euro911 ... and it's a blue flame, or so I've hear... Sep 28 2013, 09:59 AM
NORD Elliot; Make sure when you disasemble that you use... Sep 28 2013, 11:30 AM
SLITS That is the problem with using RTV in areas where ... Sep 28 2013, 09:25 PM
Elliot Cannon I finally got the head off. These are cylinders ... Sep 30 2013, 05:00 PM
Elliot Cannon The cylinder walls look pretty good to me. I can... Sep 30 2013, 05:02 PM
Elliot Cannon I pulled out one of the ceramic valve lifters. Af... Sep 30 2013, 05:05 PM
Elliot Cannon I'll be pulling the other head off soon and fi... Sep 30 2013, 05:10 PM
StratPlayer Elliot are those 94 or 96mm pistons? Sep 30 2013, 06:59 PM
Elliot Cannon
96 pistons ... Sep 30 2013, 09:20 PM
SLITS Not much wear .... you can still see the cross hat... Sep 30 2013, 08:01 PM
r_towle Can you see the valve guide on the vale in questio... Sep 30 2013, 09:23 PM
Elliot Cannon It has dual springs and I can't see anything. Sep 30 2013, 09:25 PM
72hardtop Whoever used RTV needs to be tarred and feathered ... Nov 11 2013, 02:33 PM
stugray :popcorn: Nov 12 2013, 12:28 AM
72hardtop What P/C set was used? Any idea?
The following sh... Nov 12 2013, 01:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:13 AM |
