| Elliot Cannon |
Sep 24 2013, 03:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Could this leak be coming from a crack in the head at the valve guide?
| StratPlayer |
Sep 30 2013, 06:59 PM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,361 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
Elliot are those 94 or 96mm pistons?
Elliot Cannon Oil leak Sep 24 2013, 03:12 PM
stugray My first thought was that there is nothing up ther... Sep 24 2013, 03:48 PM
SirAndy AND - B|tch slap whoever put all that sillycone on... Sep 24 2013, 04:05 PM
396 AND - B|tch slap whoever put all that sillycone on... Sep 24 2013, 04:12 PM
Elliot Cannon I ask for help and I get criticized. Sheesh. I f... Sep 24 2013, 09:24 PM
SLITS
I ask for help and I get criticized. Sheesh. I ... Sep 24 2013, 09:25 PM
Elliot Cannon OK, I'm pretty sure the inside of the exhaust ... Sep 25 2013, 02:19 PM
Dave_Darling :( I'd agree; time to pull that head and have... Sep 25 2013, 02:43 PM
r_towle could be headwork, could be junk rings.
Pull it, ... Sep 25 2013, 03:03 PM
Elliot Cannon
Pull it,... Sep 25 2013, 04:31 PM
stugray
The part that I was commenting on was the drip o... Sep 25 2013, 03:15 PM
Elliot Cannon
The part that I was commenting on was the drip ... Sep 25 2013, 04:34 PM
SLITS
So, which is better, carbs or fuel injection?
N... Sep 25 2013, 04:44 PM
Elliot Cannon
... Sep 25 2013, 10:40 PM
SLITS I would have told you that your guess at a crack v... Sep 25 2013, 04:37 PM
r_towle
I would have told you that your guess at a crack ... Sep 25 2013, 07:41 PM
Elliot Cannon
I would have told you that your guess at a crack... Sep 25 2013, 10:36 PM
Dave_Darling
... supervise you while you waited for the leprec... Sep 25 2013, 11:13 PM
Elliot Cannon
... supervise you while you waited for the lepre... Sep 26 2013, 10:34 AM
SLITS
[quote name='Dave_Darling' post='1932012' date='S... Sep 26 2013, 11:17 AM
Elliot Cannon
I would have told you that your guess at a crack ... Sep 25 2013, 10:32 PM
StratPlayer Time for a six elliot :beer1: Sep 25 2013, 08:14 PM
Elliot Cannon
I'm working on... Sep 25 2013, 10:37 PM
Dave_Darling I thought he was from the Coast, not from Vegas... Sep 26 2013, 04:17 PM
r_towle Guinness and scotch are not made from meat, right?... Sep 26 2013, 04:20 PM
Elliot Cannon OMG, I went to bed last night and the Leprechauns ... Sep 26 2013, 05:31 PM
r_towle Undercoating. Sep 26 2013, 05:48 PM
Elliot Cannon
Undercoating.
It will be painted with VHT. Work... Sep 26 2013, 10:20 PM
stugray nice job! I have said many times that you can ... Sep 26 2013, 08:19 PM
Elliot Cannon
nice job! I have said many times that you can... Sep 26 2013, 10:25 PM
Dave_Darling Inspect the head first. Look over it carefully to... Sep 26 2013, 10:40 PM
Elliot Cannon These valve guides just don't look right and m... Sep 26 2013, 10:42 PM
stugray
If you cant tell a :stir: :poke: when you see ... Sep 26 2013, 10:49 PM
Elliot Cannon
If you cant tell a :stir: :poke: when you see... Sep 26 2013, 10:56 PM
stugray The inside of those heads look too clean for some ... Sep 26 2013, 10:58 PM
Elliot Cannon
The inside of those heads look too clean for some... Sep 26 2013, 11:03 PM
stugray
Got it! I actually thought we had a pretty ... Sep 26 2013, 11:00 PM
Elliot Cannon
Got it! I actually thought we had a pretty... Sep 26 2013, 11:11 PM
stugray When I first said:
I didnt realize that you had... Sep 26 2013, 11:40 PM
Elliot Cannon Both head vents are connected to a breather and I ... Sep 27 2013, 12:00 AM
euro911 I would go through both heads. It will help to ass... Sep 27 2013, 01:37 AM
SLITS Most engines that use guides, the guide for the va... Sep 27 2013, 06:28 AM
bulitt Slits has it. The guide has moved in the head. Eit... Sep 27 2013, 06:45 AM
rhodyguy remove, straighten, and 'pretty up' the en... Sep 27 2013, 07:14 AM
lsintampa IDK,
If the valve guide were leaking, it would s... Sep 27 2013, 10:26 AM
stugray
If the valve guide is loose and leaking, that wi... Sep 27 2013, 11:04 AM
914_teener I am with Mark......, Elliot....
I'd do both ... Sep 27 2013, 12:04 PM
Elliot Cannon
I'd do both... Sep 27 2013, 12:18 PM
SLITS You two should get a room.
Can I pick on you now ... Sep 27 2013, 01:31 PM
Elliot Cannon
Can I pick on you now... Sep 27 2013, 07:02 PM
r_towle It looks like it moved.
I would re-ring it, but th... Sep 27 2013, 02:01 PM
76-914 :poke: Damn Ron, you gonna let that "rela... Sep 27 2013, 04:57 PM
Elliot Cannon Mid-rise lift makes a good work bench. Sep 27 2013, 07:03 PM
Elliot Cannon I hope I remember how all this shit goes back toge... Sep 27 2013, 07:05 PM
Elliot Cannon Both the rocker arm assemblies are totally clean. ... Sep 27 2013, 07:07 PM
SLITS When you pull the rocker assemblies get 8 each 5/1... Sep 27 2013, 08:54 PM
Elliot Cannon
When you pull the rocker assemblies get 8 each 5/... Sep 27 2013, 11:50 PM
Eric_Shea
Paint the rest of it yellow... Sep 28 2013, 12:02 AM
euro911 I hope you tagged your push rods, and if you pull(... Sep 28 2013, 02:50 AM
SLITS
I hope you tagged your push rods, and if you pull... Sep 28 2013, 08:52 AM
Eric_Shea
So we've heard... <_< Sep 28 2013, 09:46 AM
euro911 ... and it's a blue flame, or so I've hear... Sep 28 2013, 09:59 AM
NORD Elliot; Make sure when you disasemble that you use... Sep 28 2013, 11:30 AM
SLITS That is the problem with using RTV in areas where ... Sep 28 2013, 09:25 PM
Elliot Cannon I finally got the head off. These are cylinders ... Sep 30 2013, 05:00 PM
Elliot Cannon The cylinder walls look pretty good to me. I can... Sep 30 2013, 05:02 PM
Elliot Cannon I pulled out one of the ceramic valve lifters. Af... Sep 30 2013, 05:05 PM
Elliot Cannon I'll be pulling the other head off soon and fi... Sep 30 2013, 05:10 PM
Elliot Cannon
96 pistons ... Sep 30 2013, 09:20 PM
SLITS Not much wear .... you can still see the cross hat... Sep 30 2013, 08:01 PM
r_towle Can you see the valve guide on the vale in questio... Sep 30 2013, 09:23 PM
Elliot Cannon It has dual springs and I can't see anything. Sep 30 2013, 09:25 PM
72hardtop Whoever used RTV needs to be tarred and feathered ... Nov 11 2013, 02:33 PM
stugray :popcorn: Nov 12 2013, 12:28 AM
72hardtop What P/C set was used? Any idea?
The following sh... Nov 12 2013, 01:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:14 AM |
